Rear wheel backing plate
Results 1 to 9 of 9
    Member Scotsman's Avatar
    Jun 2012
    Laguna Hills, California
    42
    I was removing my rear wheel this afternoon to replace the knobbie with a new tw4 bridgstone when I discovered a crack near, and through the lug that slides onto the swing arm which holds the brake in position. A new one is available at $80.00. My question is will welding the plate weaken it or make it stronger. Also I wonder if any other forum members have experienced this brakeage. My supposition is that the previous owner replaced the rear sprocket with a smaller one (45) and did not shorten the chain, leaving the rear wheel too far extended leaving the brake too far extended from the lug on the frame causing extreme leverage on the end if the backing plate. Obviously his error was discovered as the chain is proper length now. Glad I discovered the crack before it broke off completely and perhaps locking up the rear wheel. Suggestions appreciated ------Scotsman
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    As cheap as they are, I'd replace the brake plate. I didn't do any eBay research for you on used ones, but new, here are the numbers....
    1987 through 1997 models use part number 2JX-25321-01-35 which costs 45.04.
    http://www.powersportsplus.com/parts...321-01-35.html
    1998 models and newer are part number 2JX-25321-02-35 and cost 45.04
    http://www.powersportsplus.com/parts...321-02-35.html
    So, either part number will run you 45 dollars, but I suspect the earlier model part number simply superceeds to the later part. Regardless, when you order one, they will update anything that has been superceeded automatically.
    Jun 2012
    42
    Quote Originally Posted by Ayers Garage View Post
    Jun 2012
    42
    Thanks so much for the reply---- At that price is would seem cheaper to replace than weld --You guys in the forum are the best ! ======
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by Scotsman View Post
    I don't know. I never pass up an opportunity to break out the MIG or TIG.
    Jun 2012
    125
    That's pretty poor quality cast aliminum. I don't envy the guy who has to sew up the crack with the TIG. When I heat them to powdercoat, they release vile out gassing forever. Lots of stuff down in there to get out before you are gonna get a pretty TIG weld.
    Apr 2012
    374
    Yeah, some of those aluminium alloys are pretty strange to weld on - hard to find the right rods and then they just crap out on you anyway. Better to buy a new one compadre.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    There are a few used ones on ebay right now.
    Jun 2012
    42
    Well, I had the backing plate welded and decided to use it until the new one arrives. Now, of note, while replacing the wheel and new tire I realized that it was perhaps myself that cracked that plate. Don't know for sure, but putting it on and not getting it in place correctly I certainly could have let the weight of that wheel slip backwards and put a strain on the plate. Anyway, not placing blame on others I confess that I just might have broken it myself. Now a word to the wise, be very careful when installing that heavy rear wheel. In any event, the new tires work very well and everything seems to be working correctly.--Scotsman
  1. WTB rear wheel
    By deton8r in forum TW200 Classifieds
    Last Post: 04-30-2013, 05:03 PM
  2. Rear brake cover/plate
    By flyhunter3825 in forum TW200 Classifieds
    Last Post: 03-04-2013, 02:43 PM
  3. WTB Rear Wheel
    By h0zzer in forum TW200 Classifieds
    Last Post: 02-13-2013, 03:19 PM
  4. WTB: Complete rear wheel
    By ironweld7 in forum TW200 Classifieds
    Last Post: 02-07-2013, 03:57 PM
  5. WTB Rear Wheel Hub
    By Skullhag in forum TW200 Classifieds
    Last Post: 06-27-2011, 01:16 PM
