First oil change, now a tapping sound
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree1Likes
Thread: First oil change, now a tapping sound
    Junior Member Mac313's Avatar
    Aug 2012
    6
    I just got a 2008 tw200 and thought that I should do an oil change. I'm not sure what type of oil was in it when I bought it, but I put in 10w-40. Now there is a tapping sound when the bike is idling. I just want to make sure that I didn't do something wrong with the oil change. The oil level looks good and when I unscrewed the bolt referenced in the "How to change your own oil" post, oil did leak out. Should oil just kinda leak out slowly or should I see a good flow? Does this sound ok, or do I have a big problem. Thanks
    Jun 2012
    Southern Michigan
    269
    A tapping sound that wasn't there before the oil change would concern me. At first I was thinking that you might have gotten one of the wrong oil filters, but if you have oil flowing to the head that probably isn't the case.
    Oil leaking out slowly is what I get from the bolt.
    Hopefully someone who knows what they are doing (instead of me who doesn't) will come along with some ideas.
    Apr 2011
    Martinsville Indiana
    2,089
    Did you put the filter/screen in the wrong direction?
    Aug 2012
    6
    Quote Originally Posted by Small's View Post
    Aug 2012
    6
    No. The filter is in with the slots and holes side in first, and I don't see oil leaking anywhere. I here the sound when it's idling, but it seems to go away when I give it a little gas.
    Apr 2011
    2,089
    Put ear plugs in and ride the poo out of it!
    Aug 2011
    Cayce, SC
    3,109
    Tapping is normal with these bikes. Different types of do different things to our bikes. The ticking will probably go away. Mine ticked for the first 500 miles or so but quit after an oil change.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Mar 2011
    Gobles, michigan
    1,824
    Not knowing the oil type that was in it may be the answer... What if they had 20/50w ?????? Well ride it for a while and keep an eye (ear) out for something worse.. It may take a few miles for the motor to get use to the new oil........... Is the new oil for cycle use, not just car oil???? Semi-syn/full syn, or dino oil..... Good luck. OMM.
    The Southwest
    566
    I've been watching this thread with some interest. I don't have a specific answer for the OP, but I will say using cheap oil (the Car Quest labeled brand, for example) in the Jeep 4.0 will give me intermittent tappit noise that eventually goes away after a change to good oil. Perhaps this is the case, or as was mentioned, the previous owner had a thicker oil in there. I hope it's something as simple as that or maybe it's due for a valve adjustment?
    Senior Member TdubOhio's Avatar
    Feb 2012
    Ohio
    100
    Quote Originally Posted by omm View Post
    Yeah, I'd make sure that the 10w40 you used was motorcycle specific (JASO-MA label).
    From recent experience, I found I had huge improvement in engine noise and shifting when I changed to Yamaha Semi Synth.
    While these engines are noisy, I'd be concerned if its this noticeably worse after an oil change.
    It'd be worth the $11-16 of swapping out for a higher quality oil and seeing if that remedies the problem, rather than running on it for the next 4k miles and finding you've damaged the engine...
  1. very loud tapping
    By RobRz in forum Technical Help
    Last Post: 07-22-2016, 10:20 PM
  2. puget sound washington
    By jvt in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-06-2012, 11:41 PM
  3. tapping sound
    By oceanickid in forum Technical Help
    Last Post: 04-22-2012, 09:39 AM
  4. No helmet paranoia sound
    By Stromper in forum Technical Help
    Last Post: 01-10-2012, 03:41 PM
  5. Replies: 3
    Last Post: 08-15-2011, 07:43 AM
changed my oil in car and now their is a tapping sound
just did a oil change motor is now tapping jeep wrangler
