About clutch switch
Results 1 to 6 of 6
    Junior Member prabath8989's Avatar
    Aug 2012
    10
    Dear all,
    when I buy the tw bike, clutch switch didn't work. I replace the clutch switch. Now in neutral position, I have to pull the clutch. Is it the correct way or what I have to do to correct it ? Plz help me.
    Jun 2012
    Southern Michigan
    269
    My TW will start in neutral without having to pull in the clutch.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by Bullspit View Post
    Ditto.
    Aug 2012
    10
    What about in the gear?
    It means my bike having problem. any solutions to correct this. help me.
    In neutral position pulling clutch and start is made any problem ? (Is it wrong)
    thanks for replies.
    Aug 2011
    Cayce, SC
    3,109
    Mine is still original so I can't help you there. But I did disconnect it on the ttr and solder the prongs together so now it starts in any gear or neutral with the clutch out. With it simply unplugged it would only start in neutral with the clutch in.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Aug 2012
    10
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. ignition switch
    By easternfrontnh in forum General Discussion
    Last Post: 03-19-2013, 02:13 AM
  3. clutch switch malfuntion
    By prabath8989 in forum Technical Help
    Last Post: 09-07-2012, 07:39 PM
  4. Clutch Perch and safety switch
    By surfmansd in forum Technical Help
    Last Post: 05-24-2012, 08:26 PM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
