Solenoid or Starter Motor? Clicking sometimes
Results 1 to 10 of 10
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    My TW200 is showing the beginnings of a fault. When cold, occasionally when starting the solenoid will click but the starter won't engage. Repeated clickings usually does the trick and once warm, there's no issue. I suspect the motor brushes are worn or similar but I was also wondering if the solenoid has a reputation for 'whiskering' or developing deposits on the contacts that stop it from electrically conducting at times?
    Jun 2011
    Dothan, AL
    1,715
    When mine did that, it was the battery. Try topping it off with distilled water and putting it on a slow charger over night.
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member TWisty's Avatar
    North GA Mountains
    149
    Exact same symptoms here.
    My battery connections were tight, but they weren't "good".
    Cleaned the terminals, and it fired right up.
    The Southwest
    566
    Another vote for a weak battery.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Yeah. Battery tests good at the posts, fluids are right, but it just doesn't work right...
    The corrosion between battery post and cable acts like a resistor. The longer you let it build up the less power your bike is getting from the battery.
    It's just like clogged pipes in plumbing. They need to be cleaned occasionally.
    Stephen S.
    '07 TW200:
    Jun 2011
    Dothan, AL
    1,715
    Now that I think about it, my battery cables were corroded also. Especially the negative side where it grounded to the frame. Also check the connection at the starter, mine was corroded down there as well. Once I cleaned all the contacts and installed a new battery I have never had the problem come back. You should also make it a point to start the bike in Neutral, as opposed to just pulling in the clutch. These bikes tend to start slower while in gear with the clutch pulled in. Slowing the start in this way means the spark plug doesn't get enough juice from the electrical system and can make starting take longer which in turn runs down the battery.
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by retmotor View Post
    One here too. The corrosion you see on the negative terminal (Sulfation) can be caused by loose cables or the battery itself being in poor condition (under charged).
    Mar 2012
    Singapore
    258
    Ok thanks. I'll clean the terminals.
    Apr 2012
    374
    Quote Originally Posted by tw200sgp View Post
    Top it up with distilled water, clean the terminals with baking soda in water and use a toothbrush (old one is preferable), spray the terminals with battery protector spray (technical term), and put it on a low amp charge overnight. If the battery is okay, this should do the trick. Lots of short runs can discharge a battery and the low charge output of the bike just doesn't have time to boost her back to full. Like n2o2diver suggested earlier.
    If the battery is more than a year old, it can be suspect too.
    The Southwest
    566
    ^ Yes, and even if it reads 12 volts or more does not mean it's good (volts vs amps and some other technical stuff I don't completely understand). If you're still getting clicking after doing all the above, you should still rule out the battery. Load test it. What you describe is a classic symptom of a weak battery.
  1. XT-200 - same motor?
    By dpawl31 in forum General Discussion
    Last Post: 06-20-2013, 05:30 PM
  2. How to Remove Starter Motor
    By Snake2715 in forum Technical Help
    Last Post: 06-15-2012, 02:55 PM
  3. clicking clutch
    By phazer in forum Technical Help
    Last Post: 09-06-2011, 06:00 PM
  4. WTB: TW200 motor
    By amolaver in forum TW200 Classifieds
    Last Post: 11-12-2010, 09:02 AM
  5. Tw 200 new motor
    By Cappa71 in forum Technical Help
    Last Post: 10-18-2010, 04:44 AM
tw 200 solenoid
tw200 starter motor
tw200 weak starter
weak starter 200 yamaha
yamaha tw200 starter solenoid
