Two fuses - what are they for?
Results 1 to 5 of 5
    Junior Member bluebossa's Avatar
    Aug 2012
    5
    My indicators are not working, and I went to the fusebox on the side of my TW125.
    Seems it only has one fuse, one slot is empty - Bike starts and runs and rear lamp lit.
    But is the other slot for a fuse or just for a spare?
    i.e. does the TW125 have two fuses and what do they cover?
    TW125 - 2000
    Dnepr MT10-36 - 1982
    Tennessee
    1,300
    Honestly I can't be sure for the TW125, but the 200 has a fuse and a little sleeve beside it to hold the spare. I'd take your seat and tailpiece off to check connections on the indicators, do some meter testing, etc. Obviously check bulbs too.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by bluebossa View Post
    Don't know about the 125 but I'll assume it is the same as the 200, which uses only one active 20a fuse - the bottom one. The top slot is for a spare fuse.
    Aug 2012
    5
    That makes sense - its the bottom one that has a fuse and the top that is empty so sounds like it's a spare - Thanks.
    TW125 - 2000
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    It also sounds like it blew a fuse once. Might want to get a spare in there, or pack a few in your luggage. Intermittent shorts are hard to find.
    Stephen S.
    '07 TW200:
