Bike runs but gathers revs
Results 1 to 4 of 4
    Junior Member bluebossa's Avatar
    Aug 2012
    5
    I've read a number of issues on this related to Carb adjustments but when I start my TW sometimes it runs and ticks, sometimes it runs, gathers revs then backs down to die.
    I've adjusted the pilot jet in and out and 2 turns out plus played with the slow running screw up and down.
    Any ideas or should I just try and find a new Carb?
    All looks well inside, all clean and fine and no issues on accelerator cable and return, i.e. not sticking inside...
    TW125 - 2000
    Dnepr MT10-36 - 1982
    Tennessee
    1,285
    Float height could be way off.
    Member -Jake-'s Avatar
    Feb 2012
    81
    could be a vacuum leak
    Aug 2012
    5
    Quote Originally Posted by assquatch20 View Post
    OK - float related makes sense, when I cleaned it the pin was a bit bent, I straightened it out but maybe that's stopping the float from settling.
    TW125 - 2000
  1. Runs rough when damp and cold
    By atleastbehandy in forum Technical Help
    Last Post: 06-18-2013, 11:55 PM
  2. Upcoming E. Washington Poker Runs
    By Rainman in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-24-2013, 11:52 AM
  3. 1/4 choke and it runs sweet
    By Omega Man in forum Technical Help
    Last Post: 06-04-2012, 01:01 PM
  4. 89 TW200 runs rough and sporadically
    By smw08003 in forum Technical Help
    Last Post: 11-25-2011, 11:10 AM
  5. TW Only Runs Smooth When Warmed Up?
    By 440cuda in forum Technical Help
    Last Post: 02-28-2011, 10:24 AM
