Will not start unless I pull in the clutch
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree44Likes
Thread: Will not start unless I pull in the clutch
    Junior Member STOPTATB's Avatar
    Apr 2015
    4
    Bike runs great but when I try to start it I need to pull in the clutch just about one inch don’t know what needs to be adjusted thanks for any help
    Badgerflorida and littletommy like this.
    Pleasanton, CA
    5,781
    Welcome to the forum STOPTATB!
    Make sure that your bike is in neutral when you are trying to start it. There is an interlock switch that prevents you from starting your bike if it is in gear and the clutch is not pulled in (i.e., disengaged).
    Apr 2015
    4
    Thanks but it is in neutral
    Pleasanton, CA
    5,781
    Quote Originally Posted by STOPTATB View Post
    Does your clutch work normally once the engine is started (i.e., it does not slip or drag)?
    If so, then it may be a problem with the neutral switch.
    19,023
    "Will not start" -Does this mean the starter motor is not turning the engine over, or does it mean engine refuses to run?
    6,999
    Kick stand should be up.
    Apr 2015
    4
    You win I feel stupid but thank you
    Jun 2017
    Milwaukee, WI
    1,293
    I still get fooled by all of the above, even though I have a “mental” checklist. Cheers
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Frosty Hollow
    13,169
    Welcome to the stupid club. I'm a multi-award winner myself. Please don't add to what I just said Mrs. Admiral. Thank you.
    grewen, ejfranz, maddawgj and 2 others like this.
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    338
    I just helped a friend remove his kick stand and clutch lever switches so now his TW will start and run regardless of kickstand/gear/clutch lever position. Of course, this is extremely dangerous but I ride a TW....clearly I live on the edge....
    jegarh, admiral, maddawgj and 5 others like this.
  1. Wont start in gear with clutch pulled in
    By Ledmelon in forum Technical Help
    Last Post: 06-26-2016, 06:52 PM
  2. Pull starter?
    By ssgtrillium in forum Technical Help
    Last Post: 04-11-2016, 08:23 AM
  3. Kick Start Installed... Massive clutch problems!
    By LoderUp in forum Technical Help
    Last Post: 03-29-2015, 08:43 AM
  4. Sudden pull to the right
    By FortPayne in forum Technical Help
    Last Post: 09-17-2013, 10:31 PM
  5. Clutch and Kick start
    By Henrici in forum Technical Help
    Last Post: 01-31-2011, 04:14 AM
