Transmission problems
Results 1 to 7 of 7
    Junior Member flailer's Avatar
    Apr 2012
    Hey group,
    So I buy a couple of TW's for my rental business (www.harentals.com) and one of them has recently had the case split for a reseal. I rode the bike around for about 100 miles and seemed to shift ok, but hard to get into neutral.
    Now I invented this device that allows you to put the front tire of any MC into a "bracket" that fits into a hitch insert on a car or truck. It elivates the fron tire and allows you to tow the bike behind a rig on its back tire.
    So I tow the bike about 20 miles in neutral on its back tire, and then the tire locks up. Now I cant get the bike into any gear except 1st and when the clutch is let out, even in neural, the motor dies as the drive sprocket shaft is locked up.
    So we split the case, and find that the trany 2nd wheel gear and second pinion gear are seized on the shaft.
    So I am guessing that the lack of oil from a running engine seized the gears? Does anyone have an trany assy that is newer that they can sell? Are they a pricy bit at the dealer?
    Let me know your thoughts. I guess the worst part is that I am thinking my cool invention is a bust. It really has worked grat on my 2 cycle bike.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Never tow a bike with a car, without removing the chain.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by Flailer View Post
    Hey group,
    Here's what the manual says:
    Aug 2011
    Cayce, SC
    3,109
    Quote Originally Posted by Flingwing View Post
    Shift in to fifth at 25mph. That is funny!
    In reference to the tranny problem. This is what I was talking about in the "how do you haul your tw" thread. Hauling a bike with the rear tire on the ground will cause the problems unless the chain is removed. If only there were some way to lock the steering straight so we could haul it with the rear wheel up. Oh well, a trailer or hitch hauler will do the job.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    The Southwest
    566
    ... If only there were some way to lock the steering straight so we could haul it with the rear wheel up...
    Straps? Something on either side attached from the bar ends (or close) to the rear rack? Just a thought...
    Senior Member rm_hm's Avatar
    1,619
    Just the thought of doing this scares me. If someone needs to move a bike and is pennywise. Either go with a HF trailer like Qwerty's ($299.00) or use a regular hitch carrier for bikes like our TW's or smaller ($79.00 and up). Lots of used bike trailers out there http://www.adhuntr.c...Advanced+Search
    I guess the setup would be a must if you lived in an apartment and could not borrow something.
    Tennessee
    1,297
    Yeah, it isn't as bad (but still bad) for a 2 stroke because it delivers oil differently. You're running a bike without the oil moving properly when you do this, so things are going to overheat and seize pretty quick. Your invention, while nothing new, has its applications, but you're limiting a few of them when you don't take the chain off. It's only good for extremely low speeds and short trips (like around the block) if you don't take the chain off.
  1. chipped transmission tooth?
    By decade03 in forum Technical Help
    Last Post: 06-06-2013, 10:39 AM
  2. TW problems
    By marc1n5 in forum Technical Help
    Last Post: 05-11-2013, 03:57 PM
  3. Starting Problems
    By MojoJojo in forum Technical Help
    Last Post: 10-21-2011, 12:02 PM
  4. problems with web cam
    By phazer in forum Technical Help
    Last Post: 08-19-2011, 05:04 PM
  5. Just got my first TW, having some problems
    By destroyingangl in forum Technical Help
    Last Post: 04-26-2011, 09:07 PM
anyone had problems with a yamaha tw200
tramsmission lever for tw200
tw 200 transmission issues
tw200 transmission noise
tw200 transmission problems
yamaha tw 200 transmission problems
