No spark from the plug and wrong battery terminal connections
Results 1 to 10 of 11
Like Tree21Likes
Thread: No spark from the plug and wrong battery terminal connections
    Junior Member reagan's Avatar
    Jan 2018
    Monze, Zambia
    1
    Question No spark from the plug and wrong battery terminal connections
    hi everyone,
    i need advice on the tw200 1995 model, the bike was running and packed for 20 minutes and failed to start afterwards, i discovered there was no spark, even after the changing the spark plug. is it the cdi problem?
    when were trying to find the problem, a friend connected wrongly the battery terminals and there was a bad smell and smoke coming from near the tank. what could have been burnt? kindly give adquate advice and neccessary action i should take. the bike is not common for all the local mahanics here. thanks
    littletommy likes this.
    19,023
    The ignition coil is under the tank. It is possible it shorted out. I would remove tank, etc and try to find out what smelled and smoked as the first thing. There are ways to test the various parts to see what is wrong.
    Download and read the Service Manual TW200 Service Manual - searchable pdf and it may help you or the mechanics.
    Lyterx and littletommy like this.
    19,023
    Welcome to the Forum Reagan, we try to be friendly and helpful here.
    You likely have two problems: One is the no spark and whatever caused the bike to not run after being parked for 20 minutes. The other problem would be whatever got damaged by the accidental short circuit ( bad smell and smoke).
    With more information we can try to be of more help.
    reagan and littletommy like this.
    Pleasanton, CA
    5,781
    First, locate and check the main fuse to see if it has blown.
    Mar 2015
    Ynys Môn
    4,631
    Two sides to the problem - first one is to find out what fried ......
    littletommy and reagan like this.
    - Hidden Content
    Skiing the slopes in Switzerland
    17,581
    Welcome to the forum!! Hope it's a easy fix!!
    1st John 1:9
    John 3:16
    John 3:17
    Nov 2010
    Frostbite Falls Ill
    2,719
    If you lost all the smoke from your electrics the fix won't be easy or cheap.
    Phelonius
    17,581
    It's cheap to buy some more online.
    Quote Originally Posted by phelonius View Post
    TW-Brian, Purple, admiral and 2 others like this.
    1st John 1:9
    John 3:16
    John 3:17
    19,023
    Lucas makes good smoke!
    Ken and littletommy like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,958
    Has there been a write-up on how to properly jump a bike? I do know that if the jump is from a car to never have it running. I also know it is best to ground it at the frame and to make sure the cables are connected properly. Proper procedures are cheaper than replacement parts.
  1. Those Dang Battery Terminal Nuts!!!
    By scotti158 in forum Technical Help
    Last Post: 04-01-2016, 10:23 PM
  2. . . . direct battery connections, really?
    By screaminbanshee in forum Technical Help
    Last Post: 12-04-2015, 04:47 AM
  3. Battery - which terminal should be on which side?
    By jimmytanko in forum Technical Help
    Last Post: 10-04-2012, 04:04 PM
  4. Replies: 2
    Last Post: 07-21-2012, 01:44 AM
  5. sparks from battery terminal when starting!!!
    By misterpepper in forum Technical Help
    Last Post: 10-12-2010, 03:32 PM
