Rear axle nut install
Results 1 to 10 of 15
Like Tree25Likes
Thread: Rear axle nut install
    Member ddiggerr's Avatar
    Aug 2017
    30
    Quick question as to which side the nut should be on, brake side or sprocket side.
    Many different pics online show it on either side. Some have a crown nut and cotter pin and some are with a nylon locking nut (what I have)
    I am in the process of rebuilding and do not have any clear closeup pics of rear wheel and which side it was on when removed.
    To me it would make sense to have nut on sprocket side. Only because if the axle happened to rotate, it would then be going in direction of wheel rotation and tighten on the nut rather than backing off.
    Any info appreciated as to which side is the correct (safe) side.
    jtomelliott49 likes this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    You would be correct. I just hate it when the rear axle falls out.
    Phelonius
    Jun 2014
    Bel Air Maryland
    4,170
    I actually like the nut on the right side due to the fact thatís itís easier to torque when the bike is on the kick stand. Mine have Castle Nuts and I put Cotter pins in them.
    Edit; now you got me thinking... maybe my Castle nut is only on the front ???
    jtstdub, Fred and jtomelliott49 like this.
    If Iím ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Hailey, ID
    3,404
    I've never seen any pic with the nut on the sprocket side. Every TW I've ever seen has the nut on the brake side. Neither have I ever seen a Nylock or a Castle nut on a TW.....68 ft/lbs. of torque would make it extremely unlikely to have an axle nut come loose.....well, unless you road thousands of miles of washboard.
    jtstdub and jtomelliott49 like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Dec 2017
    Western Washington
    216
    Taking a very quick look at the online parts schematics on boats.net it shows the nut on the sprocket side through 1997. Then it switches sides in 1998 and stays on the right side. The nut was listed as a castle nut until 2000, then changed to self-locking in 2001. I didnít see any footnotes saying anything catastrophic would happen if you failed to follow the proper installation as denoted by year. Be a rebel, put it where you like it. Lol!
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400ís, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    all my bikes have the nut on the brake side, no nylock and no cotter pin. never had one come loose yet
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Pleasanton, CA
    5,777
    I just checked my four TW's, ranging from 1987's to a 2007. All have the nut on the brake side.
    I don't think it makes any difference.
    Mar 2015
    Ynys MŰn
    4,630
    Ermmmm - there's supposed to be a nut on there ? ..........
    - Hidden Content
    Aug 2017
    30
    Haha. Yes
    Nov 2010
    Frostbite Falls Ill
    2,719
    No, the nut is the one installing the axle.
    Purple and maddawgj like this.
    Phelonius
  1. Rear axle nut
    By mlong in forum Technical Help
    Last Post: 05-13-2014, 08:30 PM
  2. rear axle bearing help
    By mkriley in forum Technical Help
    Last Post: 07-01-2013, 08:47 PM
  3. Hollow rear axle please..
    By rebar in forum General Discussion
    Last Post: 06-18-2013, 07:08 AM
  4. rear axle won't come out.
    By scott in forum Technical Help
    Last Post: 09-21-2012, 11:18 PM
  5. Rear axle bearings
    Last Post: 12-24-2011, 10:25 AM
