Need advice on clutch behavior!
Results 1 to 10 of 13
    Junior Member Gator's Avatar
    Aug 2012
    Sanford, FL
    10
    Love this forum and looking for some advice. I have two 2008 models. We also have an 02 and 03 in the family (my older boys use them at college instead of scooters). They were recently purchased used and I have serviced them all, oil change, oil filter, plugs, air filters, new carb float valve o-ring on one, etc. Thanks to all here sharing their experiences so I could easily learn how to service them. My question? When starting in 1st gear with clutch in, a couple of the bikes will surge a little forward. Does not happen in neutral. Is this normal? Is this a sign the clutch needs to be replaced? I tried to adjust it out with the clutch cable, but this had no effect other than gear engagement point on the lever. I have fresh Castrol 10-40 Full Synthetic 4T in them (will use Mobil 1 next time as I have learned in several posts). Any advice most appreciated. Thanks -Don
    Member drake523's Avatar
    May 2011
    Central Pennsylvania
    50
    I had the same problem with my 2003, but only on the first ride of the day. I asked the Yamaha tech at the dealership and he had no answer. His comment to me was that not much adjustment can be made on the clutch. He said the TW200 just shifts that way sometimes. I never experienced that until this year. My bike only has 1600 miles, has been regularly serviced.
    Aug 2011
    Cayce, SC
    3,109
    It should only happen when you first start it up for the day. With a wet clutch the cool oil between the plates will cause them to stick together. This is normal and nothing to worry about. If for some reason it happens more than that, you may have a problem.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Jun 2012
    Southern Michigan
    269
    Mine does this as well. I don't think it is anything to worry about as most motorcycles I have ridden have done this.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Absolutely normal. Usually happens only after it sits for quite a while, like over night. When I first start for the day, I always pull in the clutch and rock the bike back and forth a few times to 'break' the clutch free - you'll find that the bike won't really move at all at first, like you didn't even have the clutch lever pulled in. This way, there is little or no "jump" when you do put the bike in gear, easier on the whole bike. That means too that it's a very good idea with the T-Dub to always do a first start of the day in neutral as it's hard on the clutch and the starter to start cold when in gear, even with the clutch lever pulled in.
    The Southwest
    566
    I don't think I've ever owned a bike that didn't do that. A little "bump" is normal. Now if it's pushing the bike through the closed garage door, that's not normal.
    Aug 2012
    Sanford, FL
    10
    Quote Originally Posted by Flingwing View Post
    Thanks to everyone for their replies and feel at ease knowing it is normal! Not ready to tackle clutch replacement with my current tool set and knowledge. Yes, I believe it only happens the first start of the day and will be sure to watch out for it. I never really noticed until my boys pointed it out and asked me. They were recently trained at the motorcycle endorsement class here in Florida to start in 1st gear, clutch in. Dad's old habit of neutral starts is why I never noticed. Again thanks. -Don
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    Hum...mine does the exact same thing. Wonder if its normal when i let the clutch out when im parked thinking im in neutral but really in first and kill it. Haha....i think its time to get new indicator bulbs for my instrument cluster. I have the turn signal, high beam, and neutral lights burnt out.
    2008 TDUB
    Apr 2012
    374
    Quote Originally Posted by Gator View Post
    You might want to review the training handbook with your boys. Here is the start procedure phumonic directly from the MSF Basic Rider Handbook:
    . . . and what it means, all on Page 19.
    Senior Member rmcglad55's Avatar
    Fleming Island, Florida
    287
    My clutch started feeling real funny. As it turned out, I needed to adjust my chain. It felt just like a clutch problem. Also Amsoil seems to smooth it out for me.
    Rusty
    2005 TW200
    2005 Triumph Bonneville T100
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. Need some advice...
    By Woodi23 in forum Performance and Customization
    Last Post: 02-12-2013, 08:39 PM
  3. Some advice
    By renos1 in forum General Discussion
    Last Post: 10-22-2011, 06:51 PM
  4. New Guy Needs Advice
    By biker bob in forum General Discussion
    Last Post: 05-01-2011, 07:15 AM
  5. Need advice getting a used TW 200
    By Boret in forum General Discussion
    Last Post: 09-01-2010, 09:29 PM
gator rack tw200
