Carburetor adjustment advice
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree38Likes
Thread: Carburetor adjustment advice
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    928
    Can anyone suggest one or more good YouTube videos about adjusting carburetors that would be helpful to a novice like myself?
    jtomelliott49 and putt-putt like this.
    My 2-Wheel Babies: 2017 Versys X 300 - 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2014 Honda Ruckus
    Jan 2017
    Southern Nevada
    1,077
    No video suggestions, but why are you contemplating adjustment?
    jtomelliott49 likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Jun 2014
    Bel Air Maryland
    4,170
    Did you replace your bad Petcock?
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    May 2015
    Hampton, VA
    928
    Quote Originally Posted by TopPredator View Post
    No, there was nothing wrong with the petcock, it was an actual crack in the Clarke gas tank. Probably from my enthusiastic tree-hugging on the 'Ridge' ride. It was high on the underside, just above the left puck. It probably started small, but all the riding I do eventually made it grow enough to make the leak really bad. I thought it was the petcock until I got the tank off and found the crack. I've got the original tank on it for now until I sort out the carb issue.
    Quote Originally Posted by SportsterDoc
    Long story short: I bought parts to refresh Frank's carb - o-rings and needles and seals and everything. Cleaning went well. Put it back on the bike and it would idle, but died when I gave it gas. I couldn't figure out how to fix it and really wanted to ride, so I gave in and took it to the local Yamaha/Kawasaki/Suzuki dealer. Got it back and it ran - a little high strung, but it was cold so I figured it would idle down once I got underway.
    Nope.
    It ran like crap. They had the idle set way up so it was just racing to keep the engine running. When I dialed down the idle to where it had been when I first got the bike, it had a hell of a time running. So I dialed it back up. Then I realized the choke wasn't doing a thing at all. It was like the idle was set so high the choke had no where left to go.
    <sigh>
    So the hope is I can try to be patient and once more attempt to learn enough to maybe figure out how to set it myself. If not, I'll bite the bullet and take it to an independent shop and see if they have any luck. I'm an old apprentice, so I learn best visually. If I can see it done, hear the difference in how it sounds, I learn faster. Thus the request for a video.
    TopPredator, admiral and Cornelis like this.
    Jan 2017
    Southern Nevada
    1,077
    1. Did you lube (diluted soap, water, spit) the rubber when reinserting the carb? If not, maybe a vacuum leak.
    2. Is the rubber from carb to head in good condition?
    3. Did you look into the pilot jet orifice...is it a clean circle? I usually probe (gently) with a safety pin.
    4. What is the mixture screw setting? Should be about 2 1/2 turns out from a gentle seat.
    Cornelis likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Skiing the slopes in Switzerland
    17,590
    If the choke does nothing, you may have a clogged up pilot jet. I recommend a new one and larger than the stock size. One of the secrets to my build was a 34 pilot jet recommended by Ronnydog. It made a wonderful difference in how the bike started, warmed up and ran. Just my 2 cents...
    *assuming you have the older style carb.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    No videos, but lots of photos.
    Have you disassembled the carb and checked that all parts are in their proper place?
    https://tw200forum.com/forum/technica...-cleaning.html
    https://tw200forum.com/forum/technica...ification.html
    https://tw200forum.com/forum/technica...tor-float.html
    As far as tuning, Lizardbrth does a good job explaining, starting at post #4:
    https://tw200forum.com/forum/technica...y-93-carb.html
    jb
    littletommy, Cornelis and Fred like this.
    Dec 2015
    San Diego
    1,865
    There are some you tube videos.
    This one is for a similar CV carb our mixture screw is in the bottom front.
    Here is one for a different bike but it is the same process for the TW. I needed to remove the throttle cables to turn my carb and the plastic panels by the tank.
    jbfla, admiral, xupa and 3 others like this.
    19,045
    Cracked Clarke tank can be salvaged by several techniques:
    3 Ways to Seal a Plastic Gas Tank - wikiHow
    jbfla, Cornelis, admiral and 1 others like this.
    May 2015
    Hampton, VA
    928
    Y'all are the beez kneez! It's late and I need to sleep, but I fully intend to get back and read/watch everything tomorrow when I get home from work!
    Thanks my friends!!!
    Tweaker and littletommy like this.
  1. Carburetor Adjustment help
    By stevericotta in forum Technical Help
    Last Post: 04-27-2017, 03:26 PM
  2. Carburetor ?'s...
    By dwil4 in forum Technical Help
    Last Post: 01-22-2017, 02:38 PM
  3. Carburetor
    By emilliano in forum Technical Help
    Last Post: 10-05-2014, 02:32 AM
  4. Advice for shop mechanic taking stock carburetor screws out?
    By docjekyll2002 in forum Technical Help
    Last Post: 09-02-2013, 08:06 PM
  5. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 09:24 PM
