87 TDUB missing or sputtering at high speeds
Results 1 to 10 of 20
Like Tree33Likes
Thread: 87 TDUB missing or sputtering at high speeds
    Junior Member DR_Newtron's Avatar
    Sep 2017
    Socorro, New Mexico
    25
    Hello,
    I just learned how to ride a motorcycle last June and bought a 1987 TW200 shortly thereafter. I got it for $750, and it did need some work. I noticed from the very beginning that at high rpms, the engine would sputter or act like it was not getting gas fast enough. Since I bought it, I have done quite a bit of work on it including, new tires, new spokes for back wheel, new brakes, valve adjustment, new handle bars, adjusted float valve in carburetor, Used Sea Foam in gas tank several times, new drive chain, and added a DG V2 exhaust. It now runs much better, but it still has problems when I get to about 55 mph. It will do 50 mph no problem, but at WOT, when it gets near 55 mph, it starts sputtering. When I slow down just a little, it does fine. It also seems to have this issue at slightly lower speeds on long rides when the engine is hot. Do you think it is a jetting issue? I believe the bike originated in Washington. I am in New Mexico at about 4,600 feet AMSL. If so, I know nothing about carburetors or how to change the jetting, so any advice would be appreciated. Thanks!
    Talon
    Ken likes this.
    Mar 2017
    Yuba City, CA
    403
    Welcome!
    It could be a jetting issue, especially since you installed a more free-flowing exhaust.
    It could also be your CDI going bad. Commonly, when the CDI starts wearing out, it will run pretty well cold, then start sputtering or cutting out when it warms up.
    Based on your description though, I'd monkey with the jetting a bit more. Someone will chime in with more specific recommendations, I'm sure.
    littletommy, Ken and Cornelis like this.
    Vacationing in the Bahama's
    17,573
    Welcome to the forum!!
    1st John 1:9
    John 3:16
    John 3:17
    Jan 2017
    Southern Nevada
    1,077
    If you back off at wide open throttle and it gains speed, it is too lean.
    1. What number is the main jet?
    2. How high does the needle lift at WOT? (does 1987 have CV carb with a diaphragm operated slide/needle?)
    3. How does the spark plug look?
    DR_Newtron likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Mar 2015
    Ynys Môn
    4,630
    Number 3 ^^
    littletommy likes this.
    - Hidden Content
    6,998
    Stock pilot jet is #40. Stock high speed jet is #114. Jets wear out and need to be replaced. They can look perfect even using a magnifying glass but they are not. If you only want to get 2 jets from the dealer get the #40 and #114. Probably cost about $15.
    Or go to AliExpress and buy an assortment of each. They don't have a #114 but they do have a #112 and #115. Get 3 of each. And 2 #110 and 2 #118. And maybe 2 #108 and whatever else. Ditto with the pilot jets. A 3 stock size #40 and then a few leaner and richer. Total cost will be about $20 and you will have a lifetime supply or you can share them with friends. And if it still runs poorly then it probably will be the CDI. Send it to Tom Bauer and for $60 he can fix it, or spend $250 on a new CDI which you might have to do anyway.
    https://www.aliexpress.com/item/12-m...311.0.0.IBBwxr
    https://www.aliexpress.com/item/12-p...311.0.0.IBBwxr
    Good luck.
    Dec 2015
    San Diego
    1,865
    I had the same issues as you although I have the newer carb. My bikes had DG pipes put on them and the P.O. had trouble tuning the carbs, I am at sea level and needed to go up two sizes on the main jet. Also I used washers as spacers under the spacer on the needle to raise it. This improved my midrange acceleration. If your bike starts easy then stay with the stock pilot jet. I put bigger pilot jets in and now my bikes start with very little choke or no choke. Luvnot’s recent carb tuning thread has some good references mentioned in it for tuning. There is a YouTube video on how to add spacers to the needle on a TW carb.
    Here it is.
    littletommy and DR_Newtron like this.
    Member Blake's Avatar
    Oct 2010
    Castaic, Ca Los Angeles Co.
    67
    Another quick check is to turn the choke on slowly at high speed during the stutter. If the stutter decreases you are to lean. If it gets worse usually too rich.
    2016 TW200
    Dec 2015
    San Diego
    1,865
    Sep 2017
    Socorro, New Mexico
    25
    Quote Originally Posted by SportsterDoc View Post
    It does not gain speed when I back off wide open throttle. It slows slightly and stops cutting out or sputtering. The tip of the spark plug is a dull dark brown color. I do not know if you can see it really well in the attached picture or not. It may be running slightly lean. It was running rich before, and I lowered the float a little in the carburetor. It did not like it when I installed a high air flow K&N air filter. I cannot answer the first two questions. I assume the the main jet is stock, but I am not sure. If you could point me to a reference to help me answer those questions, I would appreciate it. Thanks for your help.
  1. Kentucky Kid, and cutting out at high speeds....
    By witttom in forum Technical Help
    Last Post: 07-17-2019, 07:53 PM
  2. Fat tires, 7 speeds and (maybe?) 3 horsepower!
    By TW-Brian in forum Other Bikes
    Last Post: 11-25-2018, 10:05 AM
  3. Curious about highway speeds
    By Vlakslee in forum General Discussion
    Last Post: 09-03-2016, 02:22 PM
  4. Replies: 7
    Last Post: 08-13-2013, 07:30 PM
  5. Speeds from 200 cc engines
    By Polarpilot in forum General Discussion
    Last Post: 03-10-2012, 10:09 PM
