Compatibility with cylinder head
Results 1 to 7 of 7
    Junior Member jluc's Avatar
    Sep 2012
    Marseille - France
    4
    Hello,
    My name is Jean-Luc, I live in France, I am 43 years old.
    And I have a big problem with my 89 TW 200.
    The 2 screws of my exhaust are broken. Screw are welded in the cylinder head.
    In France a cylinder head cost 740€, very expensive.
    I have seen on ebay there is one 2005 head cylinder.
    Do you think is it compatible with my 1989 TW.
    I would like repair my TW, because i like it and tw 200 is very rare in France. (Only 63 TW was sold in 1989 by Yamaha).
    Pardon for my bad english.
    Regard's
    jluc
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by jluc View Post
    Hello,
    Regard's
    jluc
    Your English is much better than my Franch, absolutely no need to apologize. Yes, they are the same part numbers:
    2005
    CYLINDER HEAD ASSY
    15A-11110-04-00
    1989
    CYLINDER HEAD ASSY
    15A-11110-04-00 (replaces 15A-11110-01-00)
    That said, you can get a new head assembly at http://www.cyclepartswarehouse.com/f...=1989&fveh=320 for $314.28 plus shipping and gaskets, etc. That's only 249€. Worth a check anyway.
    Sep 2012
    Marseille - France
    4
    Thank's a lot Flingwing.
    Your explanations are very clear
    Now I Know who is the best forum for TW 's maintenance.
    regard's
    jluc
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I assume you have broken exhaust studs that would hold the exhaust pipe flange
    They are stuck but I am sure that they are NOT welded into the head and usually can be removed albeit difficultly
    If you know someone clever let them do it but the cylinder head can be stripped
    If you can file the end flat then using a center punch make a good dimple
    Heating the head in an oven to like 200c and spraying with a penetrating oil will also help
    Get LEFT HANDED drill bits that turn counter clockwise like unscrewing and starting with a size about 1/2 the stud size drill the stud out. do a 2nd a little bigger if you have to
    Lastly even if you drill it all out then simply retap them the next size bigger and buy new studs
    Sep 2012
    Marseille - France
    4
    I am saved.
    Yes, my new mechanic has finally succeed to get the screws as Stromper said.
    A new problem, there is no ignition to the spark plug.
    I suspect that the previous mechanic has pinched beam electric by replacing the chain kit ...
    Thanks
    jluc
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    I am saved.
    Thanks
    jluc
    JLUC, as has been suggested. Your English is fine, and few of us speak anything else. Good to hear you have fixed the exhaust problem. Not sure about (previous mechanic has pinched beam electric by replacing the chain kit ). If front sprocket has been replaced, maybe when engine case was put back on a wire was pinched (grounded/short circuit). That problem had recently happened to another member. I/we will search and see if we can give a connection to your problem. Take care. Gerry
    https://tw200forum.com/index.php?/top...6-pulser-coil/
    Take care my Friend.........
    Sep 2012
    Marseille - France
    4
    Thanks.
    You are right, my first mechanics has really pinched wires.
    My new mechanics will weld again the wires this week.
    Take care.
    jluc
  1. Honda 90 With a Four Cylinder
    By ronnydog in forum Off-Topic
    Last Post: 12-15-2011, 06:15 AM
  2. cylinder head
    By ldw72120 in forum Technical Help
    Last Post: 11-03-2011, 08:09 AM
  3. WTB TW Cylinder Head
    By ldw72120 in forum TW200 Classifieds
    Last Post: 10-31-2011, 06:55 AM
  4. Head and Cylinder Work
    By ryderg in forum Technical Help
    Last Post: 05-03-2011, 12:25 AM
  5. cylinder head
    By christddel in forum Technical Help
    Last Post: 02-28-2011, 04:38 PM
15a-11110-04-00
