Front Brake Closed up with wheel off
Results 1 to 10 of 11
    Senior Member msmiller's Avatar
    Aug 2011
    181
    I am almost done with new tires sprockets and chain.... Go to mount the front rim back on and the brake pads are closed tight. So I search on here only to find it plainly stated "what even you do do not squeeze the front brake lever with the rim off. Well some how I must have during fighting to keep the bike stable on the jack. SO Please can some one tell me what I need to do? It's been four days working on this project. Now I see why it is people get paid to work on these things! But if I can get it finished I will have saved over $500.00 by doing it my self..... well mostly this forum has helped, and I did pay to have the tires mounted. Thanks again. M
    Aug 2011
    Cayce, SC
    3,109
    Take off the brake pads and use a c-clamp to push the calipers back in. Replace brake pads and voila!
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Member chickenwingsmmm's Avatar
    68
    Before doing that, probably should crack the bleeder on the caliper or take the cap off the m/c, or both.
    Aug 2011
    Cayce, SC
    3,109
    I've never had to do that in the several times i've done this on different bikes. I understand the thought behind it but I personally don't think that it is necessary. To each his own I guess.
    Aug 2011
    181
    Thanks That is just what I did. Took me a little time, would be done if I had the right chain!. Seems to me I saw on here 2009 TW stock chain was 120 link. Well with the new 14t front a new 50t rear 120 does not even come close. There is something to be said for purchasing local from the dealer to bad they want to jack the price so high. I got a DID oring chain and two sprockets for less then what my dealer wanted for a chain. But I probable would have gotten the right length from the dealer. Looks like it wont up running until next week sometime. If I had the $880.00 bucks the dealer wanted to replace the chain sprockets and tires I would have done that. Some people are not meant to mess with this stuff! Me being one! Thanks for the help. M
    The Southwest
    566
    Congrats on getting it all done. The way I look at is if I work on it and screw it up it is no different than the guys at the shop working on it and screwing it up except that they'll lie to me about it and charge me even more to fix their screw up.
    Pleasanton, CA
    5,682
    I know that you are probably discouraged. I understand, and we've all been there. Just the fact that you were willing to tackle these jobs by yourself instead of just writing a check is something you should be proud of. You've learned a lot, albeit the hard way, and will now be able to offer someone else the benefit of your experience. Congratulations and welcome to the club of TW do-it-yourselfers!
    Aug 2011
    181
    Thanks for the support... this is my only transpiration been borrowing a car to get to work and putting gas in that plus time spent on this sure makes paying for it to get done right seem a lot simpler.
    I check the forum again.... But please correct me if I am wrong 2009 TW with a 428 14T front and a 428 50T rear I will need a 122 link 428 chain YES? ( the chain length is not in my owners manual) Going to try and find one tomorrow local if not then order one on line. Thanks again for your time. M
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    Rather than trust what I read on the internets, I buy a longer chain and shorten it. i think the one I bought for my tee dub was 130 teeth. Install and shorten as needed to get the tensioners oriented properly. You can always cut one shorter within a minute or two but you can't stretch it longer.
    Aug 2011
    181
    Quote Originally Posted by Ayers Garage View Post
    Thanks thats good advice.
  1. Front wheel noise
    By Dwight in forum Technical Help
    Last Post: 03-18-2013, 07:01 PM
  2. fat front wheel mod
    By john yates in forum Performance and Customization
    Last Post: 10-18-2011, 03:53 AM
  3. Front Wheel Tow Rig
    By ezman671 in forum General Discussion
    Last Post: 09-25-2011, 01:27 PM
  4. Replies: 1
    Last Post: 09-20-2011, 07:06 PM
  5. 87-00 Front Forks/Triple Trees/Front Wheel/Swingarm
    By TWmonster in forum TW200 Classifieds
    Last Post: 09-26-2010, 09:11 AM
