main fuse?
Results 1 to 5 of 5
Like Tree8Likes
  • 1 Post By 400nitro
  • 1 Post By Mattwings
  • 3 Post By Leisure Time Larry
  • 2 Post By Fred
Thread: main fuse?
    Junior Member 400nitro's Avatar
    Apr 2015
    27
    main fuse?
    I charged the battery full, but have no power to anything . is there a main fuse somewhere? thank you.
    Ken likes this.
    Mar 2015
    Northville, MI
    779
    Yes there is Admiral posted the location. TW Fuse Location and What it Looks Like
    Ken likes this.
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Jul 2012
    Wet-ern Washington
    1,415
    Under the right side cover. There is one main ATO 20A fuse, and a spot for a spare. Also, check your battery connections for polarity, corrosion and tightness, and also check your ground connection to the bike, as that one can give people fits. Good luck, and welcome to the forum. You might also want the service manual... https://tw200forum.com/forum/technica...r-manuals.html
    Ken, Dryden-Tdub and maddawgj like this.
    - Leisure Time Larry -
    Apr 2015
    27
    thank you. I found it.
    Ken likes this.
    19,045
    Early model years had a glass cartridge fuse also located behind right ride cover.
    Ken and maddawgj like this.
  1. 1987 Main Fuse Size.
    By littletommy in forum Technical Help
    Last Post: 04-24-2015, 02:17 AM
  2. I really blew it - main fuse and more
    By MTLee in forum Technical Help
    Last Post: 08-27-2013, 03:14 AM
  3. Blowing fuse
    By fishhuntr1 in forum Technical Help
    Last Post: 07-21-2013, 03:02 PM
  4. Main fuse blew again!
    By evan in forum General Discussion
    Last Post: 07-16-2012, 05:39 PM
  5. Need help looking for a fuse on the bike.
    By kman79 in forum Technical Help
    Last Post: 03-13-2011, 07:29 PM
