Source for carb needle e-clip?
Results 1 to 8 of 8
Like Tree25Likes
  • 3 Post By Thubbadubba
  • 5 Post By Tweaker
  • 4 Post By SportsterDoc
  • 3 Post By maddawgj
  • 3 Post By SHAG
  • 2 Post By Ken
  • 2 Post By Thubbadubba
Thread: Source for carb needle e-clip?
    Member Thubbadubba's Avatar
    Sep 2013
    Central Cal
    47
    I have been looking for a while now and can't find e-clips of the correct size for my '06 TW carb needle. I bent two of them. My fingers don't work nearly so well as they did 50 years ago. I see that for $20-25 I can order a needle which comes with a clip, but I'd rather pay $5 for three clips. Or something like that.
    I finally bought the e-clip installation tool. <sigh>
    I have a 2006 with ~ 4k miles on it. 1K is mine. PO was a 80 year old guy who took good care of it. I find that it is jetted too lean and I'm afraid I'll damage it so I am rejetting it.
    littletommy, Ken and Tweaker like this.
    Dec 2015
    San Diego
    1,865
    Hi Marshall’s Industrial Hardware store here in San Diego has an amazing assortment of fasteners. If you can measure your clip I think they would put a few sizes in an envelope and send them to you. I also bought metric SS Allen head screws with lock washers for my carb bowls and SS socket head screws for my carb top. I also got my washers for shimmering the needle there.
    When I have added washers to my needles I just pull off the nylon spacer instead of removing the clip. It is kinda tight but will slide with a little effort.
    Industrial Hardware in San Diego - Marshall's Hardware
    E-Clips (METRIC) Products - Marshall's Hardware
    Jan 2017
    Southern Nevada
    1,077
    A caliper can be handy.
    https://www.mcmaster.com/#e-clips/=1b8r7l7
    Not difficult to install with just long nose pliers or Vise Grip 4LN
    littletommy, maddawgj, Ken and 1 others like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    It’s not 3 for $5 but here is the full needle and clip for only $9 2006 TW200 - TW200V Yamaha Motorcycle CARBURETOR Diagram and Parts
    I use Ace Hardwares as they also have a large assortment of miscellaneous fasteners and actually helpful and trained staff to find things like that. I’m sure Marshall’s or an Ace will have them and i would bet it is much less than $5 for 3 of them.
    Ken, Tweaker and littletommy like this.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    984
    You should be able to walk in almost any bike shop and get one. No tools required to remove or install clip. Push on and off on a hard surface like glass using thumb and index finger from other hand to keep it from going anywhere
    Ken, littletommy and maddawgj like this.
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    Quote Originally Posted by Thubbadubba View Post
    I found this one and saved it in case it is helpful. I think this site may be what you need.
    https://farmandsandtoys.com/ocart2/c...s/jets-needles
    Sep 2013
    Central Cal
    47
    > "Push on and off"
    Yes, and I have done that for 55 years. But... my hands no longer work as they should.
    Sep 2013
    Central Cal
    47
    Thanks for all the good suggestions! I ordered the needle assembly.
    littletommy, maddawgj and Tweaker like this.
  1. Base Line Carb needle setting, PICS of Carb? 1989 TW200
    By YankeePrepper in forum Technical Help
    Last Post: 04-24-2015, 06:04 AM
  2. Replies: 7
    Last Post: 05-27-2014, 06:00 PM
  3. Paper Clip in my '93 Carb..??
    By Goofy Footer in forum Technical Help
    Last Post: 01-09-2014, 02:16 AM
  4. carb needle shims
    By aladdin in forum Technical Help
    Last Post: 03-02-2013, 11:55 PM
  5. Help removing needle from old style carb
    By kennethshaw in forum Technical Help
    Last Post: 04-18-2012, 06:13 AM
