what are the two openings under the bowl?
Results 1 to 5 of 5
    Junior Member rogerrocio's Avatar
    Sep 2010
    4
    Hello, just picked up a 91 TW. It appears someone tried to tinker with it before I got it. I figured out most of the hoses near the carb. But under the carb bowl, there are two openings. One has a screw to restrict flow(i think). What is the other for(gas flows from here when i turn the petcock to on)? Should there be two hoses for the two holes? If so, where does it connect to? Thanks
    Roger
    Desert, SoCal
    7,369
    Quote Originally Posted by roger View Post
    Roger
    The rearmost one is the float bowl drain. If gas is coming out of here, the drain setscrew is backed out (the little Phillips head brass screw on the left side of the carb).
    The more forward one is the float bowl overflow (It has a slightly larger nipple). If gas is coming out of here, your float is stuck open.
    Both of these get short hoses routed to beneath the swingarm.
    Devon, England.
    614
    Roger
    One is your pilot mixture screw (the one you say restricts fuel)screw this one in all the way gently, and then back out approx. 2 1/2 turns, the other is carb drain screw, tighten that one up to stop fuel leaking when you turn on the petrol tap.
    There is plenty of experience on this forum for tuning carbs.
    EDIT. I may have contradicted lizrdbrth here as we posted at the same time, but it will be one or the other. Can you post a picture?
    Sep 2010
    4
    Post
    thank you both for the quick advice. I will try to take a picture, to clarify. but the float being stuck is a definitely suspect. you guys rock!
    Senior Member betopimienta's Avatar
    Texas
    158
    lizrdbrth's answer sounds more plausible . I have never seen gas run out of pilot adjusting hole , but the float over flow and carb bowl drains will leak fuel under the conditions mentioned by lizrdbrth's post. I had my early type [1999]TW carb apart yesterday to re-jet and add an extra washer to the needle. it now starts very easy in the morning, noon and night and warm up time is nearly Zero now. it starts and rides away smoothly now in about 10 seconds, where it used to take 2 minutes to warm up. [ #118 main jet and small washer inserted to raise the needle .]
  1. bowl leaking
    By Jassenk in forum Technical Help
    Last Post: 05-08-2013, 09:04 PM
  2. float bowl chamber
    By phazer in forum General Discussion
    Last Post: 10-13-2011, 05:40 PM
  3. stripped out bowl drain screw
    Last Post: 09-05-2011, 09:11 PM
  4. Float Bowl Screw
    By mike m in forum Technical Help
    Last Post: 09-04-2011, 07:03 AM
  5. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 02:57 PM
gas leaking from carb bowl
