Throttle response help
Results 1 to 4 of 4
Like Tree7Likes
  • 3 Post By Gastone165
  • 2 Post By elime
  • 2 Post By Tweaker
Thread: Throttle response help
    Junior Member jdnphotography's Avatar
    Nov 2015
    Nantucket, MA
    26
    I have a 2016 and feel like the throttle response is a little slow? Any ideas? My current jet settings at sea level with FMF powercore are 130 jet out of the kit and 45 pilot and 2 washers on the needle.
    Instagram: @wampanoagriders
    2016 Yamaha TW200
    Deus Surf Rack / FMF Power Core Muffler / Ricochet Off-Road Skid Plate / Rox Risers / Seat Concepts Seat
    Dec 2017
    Western Washington
    217
    45 on the pilot? On 01-13 years the chart says the stock pilot jet is 31. Seems people replace it with a 34. That’s what I did along with the 2 1/2 turns and two washers and a 130 main. My 02’ runs great now compared to what it did before. All info thanks to the TW200 forum. 👍
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    6,999
    Sounds rich. Go back to stock setting then make changes. I bet the spark plug is very black velvety carbonized.
    Dec 2015
    San Diego
    1,865
    So the 45 pilot does seem very big. I could tell my #31 pilot was too small because when I opened the pilot screw past two turns it did nothing. The #34 had a better response when opened and I could find the sweet spot. I did plug chops and high speed runs to settle on main jet at 130. What thickness are your washers? I ended up with three washers I think they are .02”. My wife’s bike had better acceration when I was using two it turned out I hadn’t pushed the nylon spacer all the way tight against the washers and e clip. So I went to Three washers. Now my bike seems a little rich in the midrange. So I may sand down a washer a little bit on that needle.
    Here is a link to plug chops.
    Plug Chop how-to
    Gastone165 and Dryden-Tdub like this.
  1. Lagging throttle response
    By Ndica in forum Technical Help
    Last Post: 06-27-2017, 08:19 AM
  2. New owner - throttle response help ....
    By cvillanu in forum Technical Help
    Last Post: 05-17-2017, 03:12 PM
  3. Bad throttle response, won't go past 50% throttle video
    By trcooperone in forum Technical Help
    Last Post: 05-10-2016, 05:46 PM
  4. Throttle response
    By Highcountry in forum Technical Help
    Last Post: 09-23-2014, 04:43 AM
  5. Slow throttle response
    By yawabala in forum Technical Help
    Last Post: 05-21-2014, 10:44 PM
news
