Clutch and Brake Levers
Results 1 to 4 of 4
    Junior Member marcuskilpatrick's Avatar
    Sep 2012
    1
    Can anyone tell me the best place to but replacement clutch and brake levers? Thanks.
    Marc (Proud new TW owner)
    Ephrata, WA
    1,125
    I bought mine at Cycle Gear. Don't remember the brand, but they had a book on the shelf with a cross reference list.
    Or, you can always buy stock ones.
    1990 TW200
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,750
    If you have a disc brake the levers off a YZ-85 will fit.
    Junior Member PerfMoto1's Avatar
    Aug 2012
    Michigan
    26
    Stock is good. There are several aftermarket companies that make one or both levers. Assuming you have the stock perch (the part that attaches to the handlebars), you have lots of options.
    According to my book, all years will use the same clutch lever. Brake levers are dependant on year. I agree with Xracer about using the lever from another model. Unfortunately, due to fitment charts, you have lots of choices that won't be listed online since the manufacturer lists the lever for something like a YZ but not the TW, even though it might fit both.
    For cost and quality, I use Moose Racing quite a bit. I think you'll find that all brands will do a good job.
    I'm a bit biased when it comes to retailers, so I'll (*cough* Perfmoto.com *cough*) stay out of it.
    Congrats on the new bike!
    Snoop
  1. Replies: 2
    Last Post: 05-28-2013, 11:00 AM
  2. Replies: 11
    Last Post: 04-15-2013, 10:24 AM
  3. Short levers
    By rbm in forum Performance and Customization
    Last Post: 04-07-2013, 10:46 AM
  4. Aftermarket Control Levers
    By Knightowl in forum Performance and Customization
    Last Post: 04-01-2012, 05:21 PM
  5. Best front brake + clutch levers?
    By TW200_CA in forum Technical Help
    Last Post: 09-16-2011, 03:39 PM
forum replacement clutch brake levers tw200
tw200 brake lever altrenative
