Stand or Jack?
Results 1 to 10 of 15
Like Tree1Likes
Thread: Stand or Jack?
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    OK guys, so what is better for the TW200 when you want to work on it (removing wheels, taking apart bike, etc), one of those stand type deals or an actual motorcycle jack?
    Thanks!
    Bart
    Aug 2011
    Cayce, SC
    3,109
    Whatever your wallet can take.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Pleasanton, CA
    5,681
    If your wallet can't take much, here's a low budget approach.
    Well, it turned out to be a little more involved than just drilling a hole in a board, but here is what I ended up with. I screwed the two 2"x11"x2' boards together, drilled a 1 1/8" hole through both boards, and mounted a pipe flange on either side of the hole.
    Here is a shot with the front wheel raised.
    The boards screwed together are now wide enough to allow the bike to balance with both wheels off the ground. This is not secure enough to allow you to work on the bike but you can now slide the pipe through and pivot the lift in the other direction to raise the rear wheel.
    Here is a shot with the rear wheel of the ground.
    Kind of cool being able to lift either the front or rear wheel just by sliding the pipe through and rocking it in the other direction without needing to reposition the lift.
    Fred likes this.
    Senior Member iowatdub's Avatar
    Aug 2012
    Iowa
    130
    A wooden box just a little taller than the bottom of the engine works good too. Just lift it up on the box. With cyclerack its pretty easy to set it on.
    2008 TDUB
    Nov 2010
    Reno, NV
    500
    Cool, thanks guys. I have a transmission jack that might work...
    Bart
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Pretty clever Brian. Seems like a 6 foot long 2x12 ought to do it. A 2x12x8 at Lowes is $9.00. The pipe and flanges are easy to get and reasonably priced. What I like is the simplicity, low cost and when that pipe is angled against the ground, things should be pretty stable. So all you need would be a saw, drill, hammer, some long nail or deck screws and a large wood bit. Do you think that you could scale down on a smaller diameter pipe, flange and bit. I would be nice to save even a few more bucks if you could still construct a safe stand. Great project:
    Take care my Friend.........
    Pleasanton, CA
    5,681
    Woohoo, I finally got a Missing Link Award from Mr. Gizmow. Thanks Gerry!
    (In the spirit of full disclosure, I actually copied this idea from a video that someone on this forum had posted here a little while ago)
    Since I already had an old board laying around, a piece of pipe, some screws and a set of wood drill bits from an earlier project, all it took for me was one trip to the hardware store for some pipe flanges.
    I wouldn't suggest scaling the pipe diameter and flanges down because it still takes a pretty good pull on the pipe to lift the TW. My first attempt used only a single board, which promptly split lengthwise at the hole (you may notice that I am now using this somewhat narrower board as a base).
    Brian
    Member bend42's Avatar
    86
    When I am at home and have much to do, I have the luxury of a hydraulic bike stand. Lifts the TW right up to a nice working height for an old f**t like me.
    But on the road, and even for chain cleaning/lubing at home, I have a very simple lifting device:
    It's made from an adjustable aluminum crutch obtained at a garage sale for $1.00, along with a u-bolt and two pieces of flat aluminum stock I had in my junk box.
    With the bike on the kick stand, I lift the rear wheel 2-3" and insert the "crutch" . In the photo, the rear wheel is about 2" off the ground, making chain work very easy. I carry this in a small box with me when I am traveling so I can do a quick chain clean and lube wherever.
    John
    Pleasanton, CA
    5,681
    Quote Originally Posted by bend42 View Post
    Hi John,
    Any chance you could post a larger picture of your u-bolt setup? I picked up a pair of crutches and would like to do something similar, but my crummy monitor doesn't have the resolution to see yours clearly.
    Thanks,
    Brian
    86
    Hi John,
    Thanks,
    Brian
    Here is a closeup. Two layers of flat stock below nuts and sitting on top of crutch [one came with u-bolt, I added piece from junk box for strength]; rubber cushion on top of flat stock. Wrapped exposed thread to minimize damage to swing arm.
    Hope this helps
  1. 4 piece crutch jack
    By DonBenito in forum General Discussion
    Last Post: 11-03-2018, 11:49 AM
  2. Trail Jack
    By r80rt in forum Technical Help
    Last Post: 07-21-2013, 10:37 PM
  3. Kick stand bolt and.....
    By Revolverman in forum Technical Help
    Last Post: 05-30-2012, 09:02 PM
  4. WTB...kick stand
    By rastaman in forum TW200 Classifieds
    Last Post: 08-14-2011, 11:04 PM
  5. TW - What's it stand for?
    By Rohnsman in forum General Discussion
    Last Post: 06-21-2011, 11:14 PM
stand
tw200 forum good jack
tw200 stand work
