Will crank, but won't start
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Like Tree30Likes
Thread: Will crank, but won't start
    Junior Member Kevinophoto's Avatar
    Jan 2018
    Honolulu, HI
    24
    Question Will crank, but won't start
    I bought a 2011 TW200 last week, when I bought it everything was fine to the best of my knowledge at the time. Shortly after buying it I was racing around on the bike, launched a start with a friend. I hit 3rd and I did the bike slowed the acceleration and started making a clicking noise from the engine. I pulled over and shut it off, checked my oil and everything. Tried to start it back up. It didn't start for athe first few times. It started after a minute with the same noise. Having a dead phone and that is was 22:00, I opted to ride home with the clicking. On the ride home, the bike struggled to hold the speed limit of 45mph. Espescially on uphills. It felt very underpowered and no where near as peppy. I was either at a high rpm with the throttle wide open or on a downhill in a higher gear. At times during the ride, I could hold it a differnt speeds and rpms for a short while to get ticking to quiet. The next day, I checked the filter for metal shavings and found a good amount of shining silver shavings. I started the bike and it struggled to idle without me giving throttle. Also when it started with the clutch pull in, it started to pull forward. Giving me the idea that the clutch was shot, honestly probably due to the fact that I am a newer rider. I rode it around the block and went to u-turn when the bike died and would not start. I even tried to bump 3 times it at 15-20 in 2nd but it would run. So i walked it home and it hasn't run since. Also while on the test ride, I confirmed my fact that the gears were shot. Barely shifts, you have to yank on it a couple times to get it to shift anyway. To my knowledge it shifted fine when I bought it and believe it was my ignorant ass that screwed it.
    I understand I am a new rider, so I did something wrong please tell me so I don't do it again.
    The spark plug fires and looks like its in great condition. I haven't found out how to check and see if the bike is getting enought fuel and would love some techniques. Don't currently have a compression check tool but going to get one if necessary. There is gas in the tank, fuel line is on, kill switch is on, in neutral.
    I know the clutch is bad, but wouldn't the bike start in neutral regardless of a shit clutch?
    littletommy likes this.
    Skiing the slopes in Switzerland
    17,581
    Welcome to the forum!!
    Did you happen to change the oil and oil filter beforehand? Sounds like your clutch cable is out of adjustment, they don't just go bad just like that.
    Quote Originally Posted by Kevinophoto View Post
    1st John 1:9
    John 3:16
    John 3:17
    Jan 2018
    Honolulu, HI
    24
    I didn't change the oil before. Haven't yet either since, to my knowledge, crappy oil wouldn't stop the bike from running. I planned to flush and change oil and filter after I fixed it. But figured I shouldn't change it prior because I would just get more metal in it.
    Thank you, I will check the cable.
    The clutch is the least of my worries, I need the bike to run in neutral and run well. But it doesn't run at all, cranks very well, brand new battery, spark plug is good.
    How does one check the fuel system to make sure the carb and everything is flowing smoothly?
    Is there any reason the bike wouldn't start, if it does start grind something while it runs, struggle to maintain an idle, have a large loss of torque and power, and make clicking noise from the top end. Is there any problem that would cover all of that or a combination of a shit clutch and something else?
    Jan 2018
    Honolulu, HI
    24
    I could see the loss of power and torque being the clutch, I saw it in a number of videos. But why won't it run in neutral? And before when it did run, why did it run like shit with a click from the engine (sounded like top end, could be either or both though)?
    Jul 2012
    Wet-ern Washington
    1,415
    When you looked at the oil filter, did you happen to notice whether or not it had four holes in one end?
    Attachment 153274
    I worry you may not be getting oil to the top end of the motor. To check this, use this procedure from the service manual of checking oil flow at the gallery bolt. It is on the right side of the engine, just above the spark plug, but facing rearward. Loosen this a couple of turns with a 10mm with the bike running. Don't take it all of the way out or you risk a mess. If oil weeps out, then it is getting to the top end. If not, check that oil filter. If there are no holes in it, it will not let oil to the top end. Remember to tighten the bolt back up, but do it gingerly hand tight, as some have broken the head of the bolt off, even when trying to torque it to spec.
    Attachment 153282
    I would next check the valves for adjustment, making sure a nut didn't come loose or nothing is broken in there. When the engine is cold, adjust the slack to spec.
    The downloadable service manual and many other useful info can be found in our Technical Write-Ups
    Good luck, and welcome to the forum.
    - Leisure Time Larry -
    Jun 2015
    Nova Scotia
    1,426
    A few thoughts related to help you better understand your new donkey...
    My clutch is sticky when I first fire it up but breaks free immediately. It gives a jolt when I shift from neutral to 1st while holding in the clutch. Grinding reminds me of an issue with the filter. The fact that your filter was catching shavings is a good sign your oil was circulating. The bike shop sold me the wrong one and my motor made grinding screeching noises after roughly 20 miles. Shutting off my engine asap saved my motor. I was lucky. Just a thought but something to be ware of. Also your spark plug can tell you a lot by the color.
    It really could be anything (a lot or a little) but I'd be hesitant to do much with it until you have a more professional diagnosis. Maybe someone will chime in who can narrow it down better. Best of luck.
    littletommy and Kevinophoto like this.
    Jun 2015
    Nova Scotia
    1,426
    If it's possible you had the wrong oil filter installed before you bought it, you can drop a little 2 stroke oil down the spark plug hole and it may unseize the piston. Once I shut mine down and tried to start it up later it seized as well and wouldn't start. You'll want to replace it with the right filter and fresh oil. I did this and the shop found no damage in mine. But I shut off quickly and got lucky. I wouldn't be in a hurry to try and start it up until you know for sure though. If this is the case it's likely you at least have damaged pistons rings.
    Kevinophoto and Fred like this.
    Jan 2018
    Honolulu, HI
    24
    So, the bike won't start. I did what you said with the gallery bolt; took it all the way out in fact and cranked it incase the similar activity might throw some oil out of it. Nothing came out.
    I proceeded to take the two 2 inch covers off the top end, one is on front side the other is on the back. I'm pretty sure they house the top of the piston springs? It appears to be well lubricated. I also took the housing for the top portion of the timing chain off, it too looks in good condition and well lubed.
    Quote Originally Posted by Leisure Time Larry View Post
    Attachment 153274
    Attachment 153282
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    Bike doesn't start what so ever now
    i would stop trying to start it, you'll only do more damage. down load the manual and start reading and checking what has been mentioned. pull oil filter cover first and check for the 4 holes
    Trail Woman and Fred like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    19,023
    Aloha Kevin, we will try to help.
    Must be darn frustrating so will not tease you about piston springs which we normally call valve springs. No big deal, we all are learning as part of living every day.
    The mentioned clicking and loss of power is not good, sounds like when I had a bent exhaust valve. One way to check if valves are closing properly and that piston is not holed is to test for compression. Without a compression tester you can gauge the engine's relative compression by simply putting finger over open spark plug hole and turn the engine over with the starter motor. Good compression will blow your finger off the hole. Anything less is a sign of mechanical trouble. Peering into spark plug hole with a bright flashlight can often give a quick inspection of piston top. Should be no holes or debris.
    As grewen suggests please download and start reading the manual to help understand and then hopefully fix your TW.Downloadable TW Owners Manuals.
  1. No electrical at all, won't start, will bump start
    By jgaff in forum Technical Help
    Last Post: 08-10-2017, 02:06 PM
  2. Won't Start - Lights all die when start engaged
    By vuldub in forum Technical Help
    Last Post: 09-14-2016, 10:39 PM
  3. TW won't start
    By Deldog in forum Technical Help
    Last Post: 06-30-2013, 06:52 AM
  4. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 08:37 PM
  5. kick start won't start
    Last Post: 01-15-2011, 06:23 AM
news
Tags for this Thread
