idles fast then dies
Results 1 to 10 of 17
    Junior Member carp123's Avatar
    Jun 2012
    3
    1989 TW california model. Run OK at operating speeds (maybe a little lean). When stopped or throttle let off initially it idles at high rpm but then slows down then sometimes dies. I have adjusted both the pilot jet and throttle stop but have not found the right combination. Any thoughts.
    Thanks
    Randy
    Jun 2012
    Southern Michigan
    269
    I'm new to the TW, but to me this sounds like a carb issue. Have you given it a good cleaning?
    Junior Member cmikimoto's Avatar
    Sep 2012
    North bend, Wa
    20
    Quote Originally Posted by Bullspit View Post
    +1 Remove the pilot jet and pluck a wire out of a wire brush like a BBQ grill brush, hold the piece of wire with needle nose and reem the jet.Your lean at idle.
    The Southwest
    566
    I was told not to clean brass (needle) with anything harder than brass. Carb parts can be very sensitive to the size of their orifices and any size change carries with it the potential of forever altering how your carb will work. I don't remember the member but someone just made a thread about messing up his carb with aggressive cleaning (even though he was very careful) and having to replace it.
    The Southwest
    566
    Regarding the OP, have you ruled out air leaks?
    Sep 2011
    Southcoast MAsshole
    2,661
    i use a welding tip cleaner and haven't had any problems...able to be reused and fits any size hole...but i also don't clean the jet to death...soak it in carb cleaner and run the tip cleaner through the holes quick and done...
    http://ww.sears.com/us-forge-welding...22207P?prdNo=1
    Aug 2011
    Cayce, SC
    3,109
    $13 for some tip cleaners? Go to a welding supply shop. I think I paid about $3 per set.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member Loppy's Avatar
    Aug 2012
    Fair Oaks, NorCal
    115
    Quote Originally Posted by Point37 View Post
    Exactly what I use too. Been using the same tip cleaner for years and years. Trick is to use it just enough to knock out the crud or varnish and not "file" the oraface. The guys are right, your carb is fouled somewhere. A good doucheing and you should be good to go.
    Those who forge their swords into plows, will plow for those who do not.
    Sep 2011
    Southcoast MAsshole
    2,661
    i def didn't pay that much...i just put that link up to show what it was...lowes will do just fine as well and is probably more available to most people...
    http://www.lowes.com/Search=welding+...g+tip+cleaners
    Frosty Hollow
    12,986
    In addition to what the others have mention (and more probable), but also check air filter if you haven't already.
  1. How Fast Can I Go?
    By Tipsy Wombat in forum General Discussion
    Last Post: 06-25-2013, 10:29 PM
  2. Fast Tdub
    By stephenmarklay in forum General Discussion
    Last Post: 03-30-2013, 03:29 PM
  3. Going too fast? :(
    By Drapes in forum General Discussion
    Last Post: 08-01-2012, 12:56 PM
  4. Bike idles fine on stand, dies when upright
    By Sloppy in forum Technical Help
    Last Post: 07-07-2011, 07:28 PM
  5. TW200 Idles and Dies
    By Quicksand in forum Technical Help
    Last Post: 10-22-2010, 03:57 PM
klx110 revving then dying
