1989 TW200 carb joint for a new Mikuni VM28-418
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By elime
  • 1 Post By tw200tn
Thread: 1989 TW200 carb joint for a new Mikuni VM28-418
    Junior Member tw200tn's Avatar
    Nov 2017
    I bought a nice looking TW few months ago that I knew had a carb problem. I cleaned it and it rode fine and then just got hard to start again. I have already ordered
    a Mikuni VM28-418 and new twister and throttle cable and eliminate the old air box. After reading through the forum I couldn't find the answer to my problem:
    on a 1989 will the original Carburetor joint pn 2JX-13586-00-00 fit the Mikuni Vm28-418 or will I need to get the newer 2008 and up joint pn 5LB-13586-02-00 and accessories or will I need to source
    another joint? I don't trust my measuring what I have versus what shows up on Thursday. The Mikuni has a 33mm intake. I would like to have everything here at once.
    Any recommendations on a air filter for a most street bike. I am happy to be rid of the old system and prefer something that's easy on/off for the space.
    thanks,
    Greg
    Mar 2015
    Ynys Môn
    4,631
    Hi Greg - nice avatar - I presume that's you in the picture ?
    The early type is more likely to fit than the post 2001 models - check with the supplier if possible first
    Welcome to the mad house .....
    - Hidden Content
    Nov 2017
    Yep I’ll call the supplier and check.
    I could look like the avatar with some work but it is a still from the 1977 Italian movie Suspiria that
    got some play last year and a 4K restoration and since there are no new ideas there is a USA
    remake to release this year.
    Thanks for the help.
    Purple likes this.
  1. Base jetting vm28-418
    By Jd87 in forum Performance and Customization
    Last Post: 02-10-2016, 06:16 PM
  2. Jets for mikuni tm28-1 and vm28 for sale
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 10-16-2013, 01:31 AM
mikuni vm28-418 tw200
Tags for this Thread
