My clutch sticks
Results 1 to 6 of 6
    Senior Member hightime's Avatar
    114
    I drive my 08's about once a week and the first time I start them the clutch is stuck. Both bikes do it. I'm thinking about parking them with a stap arround the clutch lever. Most of the time they pop loose right away , but I'm afraid it will freak out my wife if she's the one starting for the first time in a week. So far I have been and it's no big deal.
    Owen
    Senior Member mga60tw's Avatar
    Fl
    215
    Mine has also cut the engine when I put it in first. Now I just pull the clutch lever several times then put it in first and good to go.
    Member shadow's Avatar
    Sep 2010
    Boise, Idaho
    92
    What oil are you using? Have you checked the level recently? Wet clutches require oil or they don't work. Also, be sure you are using motorcycle oil as car oil tends to have friction additives that can harm clutch performance. That said, I as well start the bike in neutral and work the clutch a few time before I roll out.
    Junior Member toothy's Avatar
    Aug 2010
    Seward, AK
    4
    Mine did the same thing when I used Delo 400, I switched to Mobil 1 and it pretty much went away.
    What you describe is common in motorcycles with wet clutches. In fact, every motorcycle I've ever owned that had a wet clutch dragged to some degree when cold. I make a habit of holding the front brake when first engaging the transmission. In fact, I find holding the front brake something I habitually do when getting on any bike.
    114
    My bike has the oil the dealer put in and my wife's still has the break-in oil from Yam. The oil always has looked low to me, even when brand new. You need to have the bike perfectly straight up to get in the sight glass. That's the way they came.
    Thanks for all the tips. I think , I'll try a strap around the lever at least on hers. I can't risk her getting scared. Maybe that might be a good idea for winter storage too.
    Owen
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. Clutch Help
    By xdac in forum Technical Help
    Last Post: 02-23-2013, 06:52 PM
  3. Clutch
    By wsb1206 in forum Technical Help
    Last Post: 10-26-2012, 04:29 PM
  4. Coolest memory sticks ever
    By Petrus in forum Off-Topic
    Last Post: 12-01-2010, 10:31 AM
  5. clutch
    By bratliff in forum Technical Help
    Last Post: 09-20-2010, 07:39 PM
