Rear hub question?
Results 1 to 7 of 7
Like Tree14Likes
  • 1 Post By Miaugi
  • 3 Post By TW-Brian
  • 2 Post By taylspin
  • 4 Post By Purple
  • 4 Post By Trail Woman
Thread: Rear hub question?
    Junior Member taylspin's Avatar
    Dec 2017
    14
    Rear hub question?
    Hello all,
    New to the forum and new to the TW. I'm working on a front disk fat tire conversion for my tw and before I started cutting up good parts I had a question about the rear hub.
    If I cut/grind the weld on the drum brake side, will the shaft slide inside the lacing part of the hub? Thought that might be easier than cutting from the sprocket side. Thanks all.
    P.S. If anyone has an old junker rear hub they want to sell let me know.
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    I can't answer your rear hub question however I would like to welcome you aboard from Ottawa, Ontario.
    littletommy likes this.
    Skiing the slopes in Switzerland
    17,581
    Welcome!!
    1st John 1:9
    John 3:16
    John 3:17
    Pleasanton, CA
    5,781
    Quote Originally Posted by taylspin View Post
    Hello all,
    Yes, if you cut/grind to remove the weld on the drum brake mounting flange, you will be able to slide the flange off the hub shaft. See pictures below from trailer wheel mod thread: https://tw200forum.com/forum/performa...-tw200-11.html
    Dec 2017
    14
    Thanks
    littletommy and TW-Brian like this.
    Mar 2015
    Ynys Môn
    4,631
    Outstanding pics and info from Brian as usual .......
    - Hidden Content
    Jun 2015
    Nova Scotia
    1,426
    I can't help but imagine Purple as the golf commentary while is Brian putting on the green.
  1. WTB- tw200 rear hub
    By Spawner in forum TW200 Classifieds
    Last Post: 03-16-2017, 08:36 AM
  2. Rear Hub Questionable Damage.
    By DrTerrible in forum Technical Help
    Last Post: 06-16-2016, 09:55 PM
  3. Help - need help on rear brake hub arm
    By arenfro in forum TW200 Classifieds
    Last Post: 10-25-2015, 10:48 PM
  4. rear brake hub broke
    By mrkipper in forum Technical Help
    Last Post: 01-11-2014, 03:35 PM
  5. WTB Rear Wheel Hub
    By Skullhag in forum TW200 Classifieds
    Last Post: 06-27-2011, 02:16 PM
