CV carb vs a slide carb and how the bikes run a react compared
Results 1 to 7 of 7
Like Tree9Likes
  • 1 Post By DougDotyTW200
  • 2 Post By Purple
  • 1 Post By elime
  • 2 Post By scotti158
  • 2 Post By elime
Thread: CV carb vs a slide carb and how the bikes run a react compared
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    I done my diligence on searching and thought I found the perfect thread from 2012 i think it was but no one ever answered his question. Do they run any different, surely there is some difference in driveability, for example my 2016 does not drop rpm instantly when I slightly back off the throttle for shifts and it makes for a weird feeling shift and more problematic down shifting. Seems like a 1 second delay in the rpms to begin falling, I am thinking this is the CV carb doing this. I have heard they are a bit more adaptable to elevation changes before jetting is required as a possible plus.
    For those of you that have ridden both the CV carb machines and the older slide cars please chime in as I am curious.
    Ken likes this.
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Mar 2015
    Ynys Môn
    4,631
    Some more reading here - https://tw200forum.com/forum/technica...arb-99-tw.html - in particular post #4
    The trouble with carb comparison, it assumes that the carbs in question are perfectly tuned to the stock bike – except that this is rarely the case, and every bike is individual
    It’s a hard call ………
    Ken and jbfla like this.
    - Hidden Content
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    Flat side or pumper will give you a crisper response and most people feel like more HP but is probably the extra kick in the pants went you wack it open, I have the factory CV on my Honda XR650 and there was a mod that someone worked out to drill the pilot holes larger and it made a significant difference to the response not as good as a pumper but was an improvement for really no cost. also a pumper carb will not give as good of fuel mileage
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    6,999
    PZ30 carb. I am hearing good things about them.
    Ken likes this.
    Jan 2018
    Southern In.
    457
    Who makes it ?? are you talking about the $22 deal on Amazon ??
    Ken likes this.
    May 2013
    Groton, NY
    2,663
    My '96 has a far quicker throttle response than my '13, way easier to ride a long wheelie on the '96.
    Ken and DougDotyTW200 like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    6,999
    Quote Originally Posted by DougDotyTW200 View Post
    Get the "pumper" carburetor, with the accelerator pump on the carb. It takes a special 2 into 1 cable and you will have to make an adapter to fit the TW intake manifold.
    See what heli-mech and CJ7Pilot have done. There are others but those two installing PZ30's right now.
    https://tw200forum.com/forum/performance-customization/19693-heli-mechs-tw200-build-thread-21.html
    https://tw200forum.com/forum/performa...ay-mods-8.html
    littletommy and jbfla like this.
  1. Replies: 8
    Last Post: 10-29-2014, 11:14 PM
  2. early type slide carb
    By raffles in forum Technical Help
    Last Post: 03-17-2013, 04:43 AM
  3. early type slide carb
    Last Post: 10-10-2012, 02:38 PM
  4. Slide vs cv carb
    By greendub in forum Technical Help
    Last Post: 02-22-2012, 11:57 AM
  5. anybody try a flat slide carb. in the tw
    By dz1 in forum Technical Help
    Last Post: 05-29-2011, 07:17 AM
