Newer model engine with an older frame and wiring?
Results 1 to 6 of 6
Like Tree15Likes
  • 1 Post By beltaine
  • 5 Post By lbxr
  • 2 Post By Fred
  • 4 Post By Purple
  • 3 Post By Fred
Thread: Newer model engine with an older frame and wiring?
    Junior Member beltaine's Avatar
    Mar 2015
    8
    Hi, I would like to install a 2010 engine on a 1996 frame. Concerned about wiring harness compatability. Will I have to upgrade to a new ha4nwss and regulator? What else? Thanks. Mark
    littletommy likes this.
    Skiing the slopes in Switzerland
    17,581
    You'll end up having to replace the wiring, I'm pretty sure. Not sure about the regulator and CDI.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    338
    Quote Originally Posted by beltaine View Post
    All it takes is: Use the 1996 flywheel and left side (96) cover on the 2010 motor....no changes to wiring harness. You may have to use the intake manifold off the old 96 motor as well....really simple swap....
    littletommy, Fred, Peterb and 2 others like this.
    19,023
    Plus the new motor will have the automatic timing chain tensioner.
    lbxr and Smitty Blackstone like this.
    Mar 2015
    Ynys Môn
    4,631
    And the carb boots need changing – plus the throttle cables ….
    lbxr, Heli-Mech, Fred and 1 others like this.
    - Hidden Content
    19,023
    "And the carb boots need changing – plus the throttle cables …." Only if 2010 engine installation also includes installing the newer style carburetor too. New engine should work with old style carb and associated controls.
  1. early model frame/ late model engine
    By beltaine in forum Performance and Customization
    Last Post: 02-07-2017, 12:42 PM
  2. Newer Tank on Older model TW
    By TexGX in forum Technical Help
    Last Post: 11-05-2015, 08:08 PM
  3. Older or newer. What's the difference?
    By Dubber2go in forum General Discussion
    Last Post: 09-03-2013, 05:15 AM
  4. Newer speedometer fit an older TW?
    By Scottbenson in forum Technical Help
    Last Post: 05-12-2012, 12:31 PM
  5. newer to older electrical
    By joeband in forum Technical Help
    Last Post: 11-26-2011, 08:57 AM
