Knocking Noise
Results 1 to 10 of 12
Like Tree27Likes
Thread: Knocking Noise
    Junior Member weo58's Avatar
    Feb 2018
    Knocking Noise
    Brand new bike making knockin noise when accelerating under demand, like up hill. Knockin/vibration?....2017 200 with 12 miles on her.. Any one heard this before?? Thanks
    Biking through Africa with Cornelis
    17,597
    Welcome to the forum!!
    Typical for a new bike. They come from the factory very lean to pass California emissions. This can be solved by turning out the air/fuel mixture screw to 2 1/2 turns out from gently seated.
    Quote Originally Posted by weo58 View Post
    Ken and weo58 like this.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2017
    Milwaukee, WI
    1,301
    Pull the covers and check the valves for missing hardware or loose adjustment. I’ve heard proper assembly and torque specs during assembly can be an issue. I wouldn’t run that engine until you can find the culprit. Hope it’s easy and no damage. Sorry to have to welcome you to the forum in this way. Let us know if you need procedures for valve inspection.
    Purple, Peterb, Ken and 1 others like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Pleasanton, CA
    5,783
    Welcome to the forum Weo!
    You might want to try downshifting when you encounter a hill, your new TW has only has 196cc's.
    Nov 2011
    norcal nutjob
    3,339
    <<knocking noises>>
    i thought this was another fred hijacking thread...
    is the knocking transmission related? i got my '94 with 3500 miles and was surprised how klunky it shifted. many, myself included, have found switching to synthetic greatly improves shifting, though some suggest waiting a couple of thousand miles before changing.
    Ken, weo58 and Cascade Rider like this.
    19,073
    Manual recommendations discourage things like "accelerating under demand, like up hills" for the first 500 miles or so.
    This brings up a hi-jackable debate on proper break-in procedures for our TWs.
    Some say ride 'em hard initially 20 miles in brief blasts so that cylinder honing cross-hatching has a chance to grind and seat the piston rings properly, and if babied those cross-hatched etchings on the cylinder wall don't have a chance to mill the rings properly before cross hatching is worn away.
    Opposite school of though is to avoid at all costs building high engine heat for first several hundred miles. This what the manual refers too. Perhaps it is concern about possible accelerated wear from differential thermal expansion?
    Anyways weo58's knocking sounds unusual. Confirming valve train adjustments can be wise on a used bike but since bike is brand new & on warrantee it might be best to return to dealership so that they can tell you ""Oh, they all do that...go away" which is b better than " Hey, you worked on the bike and now your warrantee is void". Many believe it is better to start and have a paper trail of fully documented warrantee issues. I do like the Yamaha Motor Company but distrust their US dealerships.
    goldenhtr, weo58, Tweaker and 1 others like this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,491
    If I had a brand new bike that was knocking with 12 miles on it it would go right back to the dealer assuming it is under warranty. My other thought is that you are in to high of a gear for the speed.
    Ken likes this.
    Mar 2015
    Northville, MI
    779
    I wouldn't ride it until you figure it out. I would, at minimum adjust the fuel mixture as LT suggests and add some higher octane fuel (we have recreational fuel in MI, 89 octane, no ethanol that would be my choice if you have something like that locally). If it disappears, easy fix. Then you can try and see if regular fuel works with the properly adjusted carb.
    Ken, weo58 and littletommy like this.
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    985
    Check the oil level! If it's good....... Ride it back to where you bought it and have them check it out for you
    Ken, weo58 and Peterb like this.
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Dec 2015
    San Diego
    1,865
    I think lil tommy has it right my bikes had a lean knock until I got them jetted right. They knocked like the timing was off. Open up the pilot air screw to 2-21/2 turns and then try a 128 main jet. You could pull the plug and check how it looks. I bet real lean.
  1. Can you hear this knocking/diesel type of sound or is it me?
    By Skin Walker in forum Technical Help
    Last Post: 01-24-2016, 02:12 PM
  2. Knocking in the engine
    By TomDeVerne in forum Technical Help
    Last Post: 06-11-2015, 05:43 PM
  3. Knocking when in 1st gear
    By urbanredneck in forum Technical Help
    Last Post: 04-16-2015, 04:41 PM
  4. engine Knocking sound????
    By michael in forum Technical Help
    Last Post: 09-05-2013, 01:53 AM
  5. fuel knocking
    By Spanner Hand in forum General Discussion
    Last Post: 11-26-2012, 11:38 AM
