Best Better Battery Buying Basics?
Results 1 to 10 of 11
Like Tree33Likes
Thread: Best Better Battery Buying Basics?
    Sep 2012
    Northwestern Oregon
    1,092
    I need to buy a new battery for my TW. I don't need anything too fancy. I just want the best value for my money. And I want it, and the cables/terminals, to fit without being a pain.
    Can anyone help a guy out on what to buy or not buy?
    Thanks!
    Jan 2017
    Southern Nevada
    1,077
    Which TW, 2003, 2008 or 2013?
    I strongly prefer AGM (no liquid to spill, higher static voltage at 12.8, versus 12.6, handles vibration better than lead-acid)
    I think Yuasa YTZ7-S will fit the later years.
    If replacing a YB7C-A, you will need some padding, as the AGM is slightly smaller.
    A clone is stocked at my local O'Reillys as an ETZ7-S
    https://www.oreillyauto.com/search?q=etz7s
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Stanwood,Wa
    1,903
    Battery threads are about as bad as oil threads. But I would definitely go AGM. Here is one on amazon prime have it in 2 days and go ride.
    https://www.amazon.com/Power-Sonic-P...8TFZ9TB0S4FX0Y
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Hailey, ID
    3,405
    I bought that one a few years back, and this one last November: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    I think they are both fine.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2015
    Northville, MI
    779
    This is the battery I have in my TW. Two years and running strong. Left my lights on one time and drained fit, no know after effects. It did take some foam to shim it. $26 delivered when I bought it.
    https://www.walmart.com/ip/ExpertPow...&wl13=&veh=sem
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Jun 2016
    New Rochelle, New York
    1,803
    AGM replacement for "wet", no brainer:
    Even if it comes (I ordered on-line) with a charge the recommendation is to fully charge it before installation & use.
    Might be a bit of a difference between the "wet" and AGM. Imagining the same for the guys that go Lithium (even smaller and much lighter).
    Always make sure you fill the void(s) in the battery compartment. Don't want any battery to be moving around at all while you are riding. I used UHMW but solid rubber blocks would work too.
    A member here filled in this area with small containers that had compartments for small tools/fuses/tire valves/etc. Like the type you'd find at The Container Store.
    Really among one of the best simple ideas I've seen posted here. I saved pictures of it but couldn't find.
    7,000
    I bought two of these because the battery in one of my TW's was starting to give me problems so I figured the other wasn't far behind. Wonder of wonders the battery that wouldn't hold a charge for more than a day all of a sudden works perfectly and I have two new batteries sitting on the shelf.
    https://www.batterysharks.com/Sigmas...saArVfEALw_wcB
    Frosty Hollow
    13,166
    and inexpensive to boot! Of course when I need one I'll not remember you're link or that I put it into my favorites in my browser.
    Sep 2014
    Mamaroneck, NY
    2,196
    Without a doubt, Battery Tender Lithium batteries have saved me a crapload of money in the long run.
    With all of the 12v rider bikes having them except for the RE5 and the MB5, I can store bikes for YEARS and not worry about them.
    The TW has a Neutrino, and that drains the battery. All I do on that one bike is remove the negative wire and I'm done.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,411
    carefull...that one is only 5.5ah
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
  1. Battery life sucks...what battery are you using?
    By rastaman in forum Technical Help
    Last Post: 07-21-2019, 12:06 PM
  2. New battery and tw will not maintain a charged battery
    By Mr.wiggle in forum Technical Help
    Last Post: 06-27-2016, 09:06 AM
  3. Buying used bike - What to inspect before buying?
    By Skin Walker in forum Technical Help
    Last Post: 01-23-2016, 11:06 PM
  4. Replies: 3
    Last Post: 02-06-2015, 12:55 AM
  5. New owner...Back to basics!
    By OKCShooter in forum General Discussion
    Last Post: 07-28-2014, 11:50 AM
