Oil Filter Cover O-Rings
Results 1 to 4 of 4
    Senior Member jckosnow's Avatar
    Sep 2012
    Maine
    177
    Did my first oil change, very very very small leak at the bottom of the oil filter cover. I would like to change out the oring seals (i guess i pinched the big one on the cover???) on the cover, and the small one around the hex bolt. is there a part number for these? searching "oil filter cover oring" doesn't seem to work well. I'd like to pay less than the dealer charges. ---is there a master part name/number list out there for the TW?
    thanks
    --Joe
    2012 TW200, 1993 KLR650, 1992 GSX750F
    Sep 2012
    Maine
    177
    if you can find your part in their list, it will give you the part number
    http://www.onlinecyclepart.com/pages...s?aribrand=YAM
    Desert, SoCal
    7,369
    Go to Harbor Freight and buy one of those metric o-ring assortments.
    The correct size o-rings for the oil filter cover along with several others can be found in those kits. I think I payed about ten bucks for the assortment and they've payed for themselves a few dozen times over. You won't find the right size for everything, but the instances in which the kit contained the right o-ring have probably saved me hundreds of dollars over the past few years vs. buying OEM.
    Sep 2012
    Maine
    177
    thanks lizrdbrth!!
  1. Oil filter cover- long bolt broke- repair options?
    By jpscott1 in forum Technical Help
    Last Post: 02-03-2013, 03:44 PM
  2. O-rings
    By elime in forum General Discussion
    Last Post: 12-21-2011, 10:54 AM
  3. Oil filter cover leaking
    By junk munk in forum General Discussion
    Last Post: 10-25-2011, 12:15 AM
  4. oil filter cover leak
    Last Post: 10-16-2011, 06:55 PM
  5. 2001 Air Filter Cover
    By 1madhonda in forum TW200 Classifieds
    Last Post: 08-18-2011, 05:02 AM
2014 tw200 oil filter and o ring
beeg partname
tw200 leaky filter cover
tw200 oil filter o ring
tw200 oil o ring
