Torquing
Results 1 to 10 of 20
Like Tree24Likes
Thread: Torquing
    Senior Member Tjmay's Avatar
    Jan 2018
    Destin Florida
    234
    Torquing
    How important is using a torque wrench as opposed to just tightening a bolt according to feel?
    littletommy likes this.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,818
    How calibrated is your feel? All kidding aside if its just holding a seat on then go for it. However if its something on the engine or its holding something on like the swingarm then use one. Harbor Freight has some that work pretty well and don't cost a lot.
    littletommy and Cornelis like this.
    Jan 2018
    Destin Florida
    234
    Thanks for the advice.
    I know I should listen to it and I will but I need to know why.
    Without try to cram several years of engineering school in an answer, what is the reasoning behind torquing a bolt as opposed to just muscling it tight?
    Cornelis likes this.
    Stanwood,Wa
    1,903
    Not breaking it off.
    Cornelis, Fred and littletommy like this.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by goldenhtr View Post
    Or having it come loose or stretching a bolt so that it may break in the future.
    Or having it so tight, that the head strips when trying to remove, especially on Allen or Torx heads.
    At my age**, I am not likely to use a torque wrench, but one is advised for head bolts, etc.
    ** In my youth I broke enough to get a feel for it.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Jan 2018
    Destin Florida
    234
    All very good and understandable reasons.
    Thanks...
    Member Downs's Avatar
    Dec 2017
    Greenville, Tx
    69
    The three wrenches linked below will take care of any fastner I can think of on a motorcycle and cost less than 100 dollars for all three. Before you get turned off by the name, some car rag did a test on these compared to more expensive brand and found their accuracy to be comparable.
    https://www.harborfreight.com/1-2-ha...rench-239.html
    https://www.harborfreight.com/3-8-ei...rench-807.html
    https://www.harborfreight.com/1-4-qu...ench-2696.html
    those torque specs exist for a reason and while I don't torque every single faster I tighten down I torque anything down that has to do with controlling or suspending the motorcycle. Brake calipers, axle nuts, pinch bolts, ect, ect
    2004 VSTROM 650
    1978 GS1000
    Senior Member Chip's Avatar
    May 2017
    WI
    267
    At my age I've learned it's not worth the risk of breaking off bolt, rounding allen screws etc. The whole 2 minutes it takes to get the torque wrench is time well spent.
    For example my Quigley 4x4 van needed u-joints on the front axle. Well some POS that was well trained, tightened the little cap allen screws so tight I could not remove them. Actually rounded out a third, then broke a third of them off. So I had to grind off and destroy a $150 set of locking hubs to repair the joints. It may not be you who gets burned the next time you use your highly calibrated hand torque wrench. Do it right the first time, torque to spec.
    Ken likes this.
    2017 XR650l
    2014 NC700X
    2005 ST-1300
    Wanted TW450
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,411
    or, if your like me, i used a torque wrench once on theTW and didn't like not being able to feel anything through the wrench, so it went into the drawer and has never come out again. i'm lucky enough to have never stripped or broken, or lost any fastener on any bike yet. so i guess it just boils down to the individual
    Ken likes this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,963
    If it's big I torque it. If it's small and critical, pinch bolts etc I cautiously torque it. I have only broken small fasteners with a torque wrench. Many times you can't get access for a torque wrench. You have to learn power control. I learned to torque lug nuts after it took 3 people to break them loose. Get a torque wrench which works for you. I have an old needle type torque wrench I trust if I can access the bolt. The click type I trust less and it doesn't detect low torques which can break them off.
    grewen likes this.
  1. Valve Adjustment, Torquing Question
    By XmasChris in forum Technical Help
    Last Post: 01-20-2014, 10:53 AM
