Pro Cycle 2001 carb rebuild kit
Results 1 to 10 of 10
Like Tree9Likes
  • 1 Post By msmiller
  • 3 Post By smthng
  • 1 Post By littletommy
  • 1 Post By jbfla
  • 2 Post By msmiller
Thread: Pro Cycle 2001 carb rebuild kit
    Senior Member msmiller's Avatar
    Aug 2011
    184
    Anyone get use the carb rebuild kit for ‘01 and higher TW? It comes with a small oring that does not show a place for it on the Yamaha 2001 supplement pdf Im trying to rebuild this car off of. However pro cycles discription of the kit it list the oring along with the needle valve. Does anyone know where the oring goes? Thank you for your time.
    Biking through Africa with Cornelis
    17,597
    Valve seat set #14 according to the pic isn't it?
    1st John 1:9
    John 3:16
    John 3:17
    Aug 2011
    184
    The valve seat set came assembled with its own oring. This is a smaller oring and from the first pic from pro cycles site is list the oring as going with the float needle. Thanks
    littletommy likes this.
    17,597
    Then I would say it goes on #13, the needle valve.
    Quote Originally Posted by msmiller View Post
    1st John 1:9
    John 3:16
    John 3:17
    Member smthng's Avatar
    Aug 2010
    Jacksonville, FL
    51
    I literally have my '03 carb bits sprawled out in front of me... the only other O-ring that I can find or remember is the one that goes on the end of the pilot screw. The pilot screw "stack" from bottom to top is screw - spring - washer - o-ring. It's in the second picture of this post ( the sideways picture ).
    littletommy, msmiller and jbfla like this.
    17,597
    I would think it should go on the needle valve seat in the sideways picture, unless it looks smaller than that. If it is, you may be right.
    Quote Originally Posted by smthng View Post
    msmiller likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Aug 2011
    184
    Thank you! Thank you! Thank you! that’s it. I guess the pdf file I’m using is incorrect. It does not show the spring or washer or o-ring. Maybe that is why the pilot screw tip is just sticking out of its hole into the carb barrel.
    17,597
    Sorry, thought my response in my post #6 above was to msmiller. I wasn't paying attention.
    Thanks for the help smthng!
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,403
    I believe Pro Cycle's description is wrong or misleading.
    As smthng suggests, the tiny o-ring goes on the pilot screw.
    Thanks for linking the photo....looks like I need to fix the photo orientation.
    jb
    EDIT: photo is fixed.. .thanks LT.
    Aug 2011
    184
    Quote Originally Posted by jbfla View Post
    jb
    I agree jbfla I think they are getting the needle names mixed up. At least they mention the o-ring which got me thinking something is wrong. There’s a lot of pieces when you have your old parts, rebuild kit and jet kit. I had disregarded the pilot screw spring as “extra” thankful for this place hope to share a short video of me firing it up this weekend. This is what my TW looked like after doing a lot of work on it. New steering bearings, fork boots, clutch pack, throttle cable, new tires self mounted, new chain and sprockets, new outer shaft bearings and seal. That was September 2016 I should have cracked the case and found the chain guides worn but time and money didn’t allow. Here’s what the piston top looked like when it died in March 2017. IMG_5282.JPGIMG_2935.JPG
    littletommy and jbfla like this.
  1. Pro Cycle gasket kit
    By c.salt in forum Technical Help
    Last Post: 08-11-2017, 01:10 PM
  2. 2001 + all balls rebuild kit for trade
    By Kavanjer in forum TW200 Classifieds
    Last Post: 02-23-2017, 05:57 PM
  3. Pro cycle raised fender kit with cycle rack?
    By Brad in forum Performance and Customization
    Last Post: 07-07-2015, 01:32 PM
  4. Pro Cycle super Moto front finder kit.
    By ZDR1 in forum Performance and Customization
    Last Post: 07-05-2015, 11:49 PM
  5. Carb rebuild kit
    By FTW200 in forum Technical Help
    Last Post: 07-02-2014, 05:43 PM
