Starter Problem
Results 1 to 10 of 10
Like Tree20Likes
  • 2 Post By Tjmay
  • 2 Post By jshaw0102
  • 4 Post By Prairierider
  • 1 Post By Tjmay
  • 2 Post By Purple
  • 2 Post By Prairierider
  • 1 Post By Tjmay
  • 5 Post By SportsterDoc
  • 1 Post By Fred
Thread: Starter Problem
    Senior Member Tjmay's Avatar
    Jan 2018
    Destin Florida
    234
    Starter Problem
    Just as I’ve resolved most of my other issues, another one popped up.
    My starter will sometimes work but mostly now just clicks.
    The battery is fully charged, the terminals at the battery are tight and the safety switches are all doing what they should or it wouldnt click.
    So, what am I missing..
    Ken and Smitty Blackstone like this.
    Junior Member jshaw0102's Avatar
    Apr 2015
    4
    Quote Originally Posted by Tjmay View Post
    Sounds like the classic symptoms of a failing solenoid.
    Sent from my SM-J327R4 using Tapatalk
    Junior Member Prairierider's Avatar
    Jul 2017
    S.E. South Dakota
    21
    Just to confirm a good battery, put a voltmeter on it when you push the start button. It should not drop much below 10 volts.
    1999 TW200, 2001 KAWASAKI KLR650, 1980 HONDA XR200, HONDA1982 XR200 IN CR250 FRAME, HONDA ATC200X, 1975 HONDA CT90
    Jan 2018
    Destin Florida
    234
    Quote Originally Posted by Prairierider View Post
    Would it register any drop if the starter motor did not engage?
    Ken likes this.
    Mar 2015
    Ynys Môn
    4,641
    The starter motor relies on carbon brushes - cheap as chips - check first .....
    - Hidden Content
    Jul 2017
    S.E. South Dakota
    21
    If your starter was locked up or shorted it could show a large voltage drop.
    Jan 2018
    Destin Florida
    234
    Got it...
    Ken likes this.
    Jan 2017
    Southern Nevada
    1,077
    Every M/C rider should have a voltmeter/ohmmeter (multimeter) and post voltage values when asking about a problem:
    1. KEY OFF battery voltage, at the battery: Normal is 12.8 (AGM battery), or 12.6 (standard lead acid battery) for no load. If just taken off a charger, voltage may be 13 point something. The battery needs to sit for a while before a reading is useful, or turn on key for a few seconds for headlight load to settle battery voltage. In the case of a bad cell, the other cells overcharge and give an almost normal overall reading, until load is applied.
    • If lower, then battery is discharged and needs charging or
    • Battery has a bad cell
    2. KEY ON battery voltage (headlight on): Normal is not under about 12.5 initially, but will decline the longer that the headlight is on, without the motor running. Under no load, 12.5 volts indicates 50% discharge, but under load, it is just voltage drop.
    3. KEY ON battery voltage while cranking: Normal is not under 10.5 volts
    • Battery has a bad cell or
    • Battery cable(s) have high resistance or
    • Starter draws too much current or
    • Solenoid contacts have high resistance
    4. If the bike is running, battery voltage at about 2,000 RPMs should be 13.8 to 14.8 volts
    Ken, Trail Woman, Fred and 2 others like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    19,059
    +1 on the above. Certainly follow Sportsterdoc's info paying attention that for every symptom ( like the voltage drop ) there are usually several possible causes like noted in his item #3. Always test your assumptions and the conclusions drawn therein before moving on.
    For example every cable has two ends. Just because the terminal on end passes inspection why would you assume other end is good and tight, corrosion free without broken wires, etc unless you test/inspect it somehow. Multimeter can tell you voltage drop across cable, line impedance, etc to help evaluate health of that but one element of the starter system. Each element under suspicion can be similarly evaluated from battery to starter motor brushes and commutator conductivity.
    Multimeter is extremely good at helping test one's assumptions and identifying problems.
    Smitty Blackstone likes this.
    Sep 2014
    Mamaroneck, NY
    2,196
    +2 on SportsterDoc's excellent explanation.
    Thank you for sharing this in a clear manner.
  1. starter problem
    By Tiny-Wheel-200 in forum Technical Help
    Last Post: 11-01-2017, 02:42 PM
  2. Starter
    By Brian T in forum Technical Help
    Last Post: 08-31-2017, 04:32 PM
  3. starter.
    By arrowsmith in forum Technical Help
    Last Post: 05-27-2016, 01:25 AM
  4. Kick starter
    By ZDR1 in forum Technical Help
    Last Post: 06-14-2014, 11:21 PM
  5. starter
    By hootie66 in forum Technical Help
    Last Post: 03-26-2013, 12:22 PM
