2013 used replacement engine for an Ď09
Results 1 to 8 of 8
Like Tree19Likes
  • 2 Post By msmiller
  • 2 Post By DougDotyTW200
  • 4 Post By DougDotyTW200
  • 3 Post By msmiller
  • 2 Post By littletommy
  • 2 Post By Ken
Thread: 2013 used replacement engine for an Ď09
    Senior Member msmiller's Avatar
    Aug 2011
    184
    http://marksmiller.smugmug.com/Other...ts/i-xWM4J4m/AJust pulled from the used engine not cleaned yet not that it needed it
    Not cleaned yet
    2013 used engine looks fantastic so far. I was going to open both sides but after opening valve covers and looking around the whole engine, oil filter, breather tube, everything is looking brand new. Going to fill it with oil and turn it by hand check the valves new plug cause I have it. Might get to turn it over tonight.
    I donít remember the white plastic part in the front sprocket chamber on my Ď09 maybe it was missing
    Do I need to be concerned over the paint on the valve springs chipping off?
    See 4th pic.
    Didnít get it installed today. Spent some time cleaning and laying parts out. Cleaned the oil filter and checked the valve clearance both where right on. Didnít remove the sides thinking this engine is barely broke in. Still was a full day and feeling good and tired. Will be attempting mounting the engine tomorrow. If I can figure out how the pdf file I have has really crappy images. Canít find anything showing me what bolt goes where
    Got the engine mounted it got easier going along I started remembering where things go. Got stuck on two things one was a brain fart. My old neutral wire was still attached to the frame and the engine came with one attached to the neutral switch. So at some point was thinking Iíd have to reach out here to see what this extra electrical connection was like I said brain fart.
    The other itís the throttle return spring just canít see to get it right. Thatís where Iím at might just try kicking it over and calling it a night.
    Got it to run first try going to upload a video ASAP (tomorrow from work)
    Still need to mount tailpipe and fix the throttle return spring.
    Dryden-Tdub and Ken like this.
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Are you re-powering a bike that had an engine die ?? What brings you to this point. I would not take anything apart further either. Should be pretty straight forward, happy to swap text pics of one together if it would help ?? let me know...
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Aug 2011
    184
    Quote Originally Posted by DougDotyTW200 View Post
    Yes my Ď09 has over 50k miles on it March 2017 the motor died. Going to be back at in the morning. Cool Thank you! i just might need to take you up on those pictures.
    Jan 2018
    Southern In.
    457
    I'll pm you a phone #, I have found so much information and help here, that I would be glad if there is anything I could do to help someone else.
    Miaugi, littletommy, Ken and 1 others like this.
    Aug 2011
    184
    Yes this forum is a great place. Wouldnít have gotten this far with this bike without it.
    Miaugi, littletommy and Ken like this.
    Biking through Africa with Cornelis
    17,595
    Great forum attitude Doug. +1 bro!!
    DougDotyTW200 and Ken like this.
    1st John 1:9
    John 3:16
    John 3:17
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    50,000 miles on an 2009, that's a lot of miles. Mine is a 1993 and I am over 44,000 miles. The only thing that actually made mine not run was the valves. I did a valve job and replaced the timing chain guides and everything has been fine. I did measure the bore and piston for wear when it was apart and it was still in spec. Your old engine may not be that worn. Yamaha did a great job on these engines.
    Tweaker and msmiller like this.
    Aug 2011
    184
    2013 Used engine and Carb rebuild Fires up on first try
    http://marksmiller.smugmug.com/Other...ts/i-xWM4J4m/AYes i think for the most part my old engine is worth rebuilding might just do that and have a spare plus the knowledge of doing it.
    Quote Originally Posted by Ken View Post
    Ken and Dryden-Tdub like this.
  1. Engine Replacement
    By MykieG in forum Technical Help
    Last Post: 05-16-2016, 09:04 PM
  2. Seal replacement during chain/sprocket replacement
    By TWROG in forum Technical Help
    Last Post: 02-03-2015, 12:42 PM
  3. Replies: 7
    Last Post: 10-24-2014, 08:51 PM
  4. 2013 with 3500 miles blown engine.
    By Kosovo101 in forum Technical Help
    Last Post: 09-01-2014, 07:56 PM
  5. Engine oil cap breather tube replacement
    By zil46 in forum Performance and Customization
    Last Post: 05-11-2013, 12:45 AM
