left side handlebar control
Results 1 to 10 of 16
Like Tree27Likes
Thread: left side handlebar control
    Junior Member my87tw's Avatar
    Feb 2018
    8
    Does anyone know what the differences are for the left side handlebar switch control, from 87 to some of the late model TWs? Wire length, plug end, color code? The Hi/Lo switch on the 87 I bought is broken off even with the slideswitch slot and is NLA from mama Yama.. Thanks in advance.
    jtomelliott49 likes this.
    Jun 2014
    Bel Air Maryland
    4,170
    The only thing I know thatís different Between them is...
    Old Style: You manually push the turn signal switch left and right to select and cancel the siginal
    New Style: You manually push the selector left and right to select the siginal. Then push the button in to cancel.
    I didnít know this until I owned both a 1988 and a 2006
    my87tw and jtomelliott49 like this.
    If Iím ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    19,019
    Likely both styles are very similar since functions are identical. Switch group should be interchangeable if one is willing to make any needed changes to wiring length or plug style.
    If replacement cost for Yamaha switch cluster seems steep there are numerous affordable aftermarket switch groups. And if this is unattractive another option is to disassemble and repair the existing switch. Anything is possible to a confident fabricator.
    2006 TW200 "Nibbler", a.k.a. ďMr.Gizmo"
    Hidden Content All Things Considered Iíld Rather Be Motorcycling
    Feb 2018
    8
    Is the wiring the same length and the plug ends the same for those year models? I found an NOS one on Fleabay, but it seems pretty high since I know what dealer cost was when the OP was still available, so I'm debating just buying a good used one and being done with...I'm not doing a points correct restoration or anything close to it and therefore don't mind the changes of the control switches. However I don't want to splice the control wiring. Just looking to get it street legal for state inspection/title purposes, and of course all systems have to be operation for the DMV to sign off on an out of state vehicle..
    Jun 2014
    Bel Air Maryland
    4,170
    The problem I ran into with the old style controls is rust. Itís amazing though they look like hell but still function.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    Senior Member Heli-Mech's Avatar
    Jan 2014
    Dartmouth, Nova Scotia
    379
    I have a LH control pod off a 91 TW200 if you are interested? Shoot me a PM.
    Fred, littletommy, my87tw and 1 others like this.
    Feb 2018
    8
    Quote Originally Posted by Heli-Mech View Post
    I'd be interested in seeing a photo or two if you like to email those to me..
    [email protected]
    littletommy and jtomelliott49 like this.
    Jan 2014
    379
    Quote Originally Posted by my87tw View Post
    [email protected]
    With an email like that .... parts shouldn't be an issue for you!
    I'll dig it out tonight and send you a few pictures. It was working fine and on my bike up until a month ago when I decided to make it a trail only bike.
    Feb 2018
    8
    Thanks man...Unfortunately the control is NLA from Yamaha or I'd buy a new one. I'm good with good used parts that function. I have Paypal BTW..
    Jan 2014
    379
    I dug out my 91 LH control pod last night and remembered the harness had been cut and spliced back together. I attempted to retrofit a newer 2005 XT225 control pod I had and wanted to use the 91 TW200 control pod harness connector to make it plug and play. Unfortunately it didn't work out as planned so I spliced the control pod back together. I also need to keep the H4 branch for my current LED headlight retrofit. Sorry to get your hopes up.
  1. left side leak
    By mrx916123 in forum Technical Help
    Last Post: 04-28-2015, 11:36 AM
  2. left side leak
    Last Post: 04-06-2015, 03:38 PM
  3. Left side handlebar perch....
    Last Post: 07-22-2014, 05:47 PM
  4. ***FOUND***WTB left side (stator side) case for a 1996.
    By Pelon in forum TW200 Classifieds
    Last Post: 07-21-2014, 12:37 PM
  5. Problem with turning signals / left handlebar switch issue?
    By elasmomark in forum Technical Help
    Last Post: 01-01-2014, 12:23 PM
