Fuel Leak or Operator Error / Ignorance
Results 1 to 10 of 10
Like Tree14Likes
  • 1 Post By M C Toyer
  • 5 Post By Leisure Time Larry
  • 1 Post By Ken
  • 3 Post By admiral
  • 3 Post By phelonius
Thread: Fuel Leak or Operator Error / Ignorance
    Member M C Toyer's Avatar
    Feb 2014
    North Texas
    85
    About a month ago I filled the tank and parked my TW in the shop. Recently I noticed a wet spot on the gravel floor.
    I thought the leak was from filling the tank when vertical and leaking from the cap when parked but discovered the tank was nearly drained. (Discovered by running fully dry a few miles from home). I may have left the switch on Reserve when I filled and parked.
    Would this cause all the fuel excerpt the Reserve to leak out or should I be looking for another cause?
    M C
    Ken likes this.
    Jul 2012
    Wet-ern Washington
    1,415
    Yeah, if you left the petcock in the ON or RES position when parking, and your float needle doesn't have a good seal, it sure could've all leaked out. Hopefully, it all just leaked out of the carb overflow onto the ground, but I would check to make sure none made its way into the engine oil or the airbox.
    If you change your needle and seat inside of the carb, be sure to read up in the technical write-up section so you don't break off a float post.
    Good luck!
    Ken, admiral, SportsterDoc and 2 others like this.
    - Leisure Time Larry -
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,963
    I filled up a crankcase twice with gasoline so I make sure I turn the petcock off. It did remove a lot of sludge so it was actually good that it happened and even better that I caught it before starting. I read about it exploding the oil pan off. That was on my Radian. The ethanol gas doesn't seem to be good for the needle valve.
    SportsterDoc likes this.
    Frosty Hollow
    13,166
    Quote Originally Posted by Leisure Time Larry View Post
    Good luck!
    In addition to what LTL mentions about the float needle, I had a bad O-ring on my needle valve seat which also allowed fuel to enter the float bowl (and beyond) onto the floor/ground.
    Both the float needle valve and needle valve seat are shown in the photo below courtesy of forum member jbfla's carb photos.
    Purple, SportsterDoc and Fred like this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Last year I had a puddle of gas under my Honda in the garage.
    My problem was radiating cracks from around a mounting bolt of the tank. I had to buy a new gas tank.
    Check for cracks. Clean the tank and dust the suspect areas with talcum powder. A wet spot should soon show if it is leaking.
    If you have no talcum, flour will work too.
    SportsterDoc, Fred and Peterb like this.
    Phelonius
    Jan 2017
    Southern Nevada
    1,077
    Excellent replies from Larry, Ken, Admiral and Phelonius.
    If not a tank issue, either the fuel vented from the carb or went into the crankcase.
    Does the crankcase smell of gasoline?
    MC, how did the Triumph jacket work out?
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Feb 2014
    North Texas
    85
    Thanks guys. Looks like I've got some work before I play.
    Never even thought about fuel in the crankcase.
    In my younger days, when I had an excuse for ignorance, had a fuel pump diaphragm rip in a slant 4 Pontiac Tempest. The superheated fuel in the crankcase was forcing oil out the breather which was collecting on the rear tires which were nearly bald. The front engine Tempest had a Corvair transaxle in the rear and though not as prone to over-steer, was still a pretty wild ride with near zero traction.
    Fred likes this.
    Feb 2014
    North Texas
    85
    Quote Originally Posted by SportsterDoc View Post
    Great! Perfect fit. I've worn it several times this winter with all the armor and liner, then just the shell when not riding. This week it's been in the 80s so I've gone bare.
    Hailey, ID
    3,405
    Quote Originally Posted by M C Toyer View Post
    See this thread: https://tw200forum.com/forum/technica...carb-leak.html
    Most likely the same problem.
    And it is VERY likely most of that gas ended up in the oil.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jan 2017
    Southern Nevada
    1,077
    Great! Here, in the summer, it is down to gloves, a long sleeve T shirt, jeans and boots.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. Speedometer error?????????
    By hightime in forum Technical Help
    Last Post: 02-13-2019, 03:16 PM
  2. Fuel leak
    By afloatafloat in forum Technical Help
    Last Post: 06-04-2016, 09:24 PM
  3. Fuel Leak at inlet elbow of carburator
    By theedge900 in forum Technical Help
    Last Post: 07-11-2014, 06:28 PM
  4. Replies: 17
    Last Post: 04-13-2013, 05:36 PM
  5. WTB operator peg left
    By wdaloz in forum TW200 Classifieds
    Last Post: 10-25-2012, 12:25 PM
