Front Fork Drain Plugs
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree42Likes
Thread: Front Fork Drain Plugs
    Feb 2018
    Western Pa.
    319
    I was very surprised and disappointed to discover that my new TW does not have drain plugs for the front forks. I have been changing fork oil since I had my 1968 CL 175 Honda! it was rumored back then that the Japanese used fish oil in the forks and replacing it with transmission fluid helped handling. I don't know but that oil sure did stink!
    Has anyone drilled and tapped their own drain plugs for the forks?
    jtomelliott49 and Ken like this.
    19,052
    Does Yamaha proudly call this Anti-Progress or Reverse Evolution? Part of the "Tit for Tat" program?...you want a disc brake, gonna cost you a kickstarter. "Hey, since we gave you a CV carb so no more fork drain screws". What did you expect for a fourteen dollar a pound motorcycle?
    Frosty Hollow
    13,170
    I've never heard of anyone here on the forum taping a hole for the drain plug hole. The good news is you can still change your fork oil as you've done in the past. Bad news is your gonna have to remove the fork tubes to do it.
    Feb 2018
    Western Pa.
    319
    I'm surprised - compared to some of the stuff you guys do it seems like a pretty simple mod. I only have 32 miles on mine(damn Pa weather) so I won't be changing too much on my bike at least until the factory warranty is up.
    Pleasanton, CA
    5,782
    I seem to remember Lizrdbrth discussing this. I also thought that for a year or so after Yamaha removed the drains (2001), the lower fork legs still had the nubs on the castings which would make tapping drain holes easier. They were probably just using up their old inventory. I know that by 2005, the nubs were gone.
    Jun 2015
    Nova Scotia
    1,431
    Maybe drill and tap an insert with red loctite and then the bolt threads into the insert so that you've got more thread on your drain bolt.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,488
    "Anti-Progress or Reverse Evolution"
    Has anyone bought a new small engine (lawnmower snowblower etc.") without a oil drain plug? Honda says to turn the engine upside down or on its side lol Briggs & Stratton tell you to just add oil and don't bother changing it. WTF? All things old are gold.
    Ken, Lyterx and Smitty Blackstone like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,968
    I've had some old engines it was impossible to get to the oil plugs. Flip them, drain them and fill them. They should be manufactured in there is no debate there. Maybe a new job opportunity tapping and installing usable maintenance items on newer engines.
    Peterb likes this.
    Feb 2018
    Western Pa.
    319
    My 2015 Mini Cooper doesn't have a dipstick for checking oil! I am supposed to trust the computer! At least I don't have to turn it over to drain the oil - so far It makes me wonder if it is worth keeping a vehicle anymore after the warranty runs out.
    Lyterx, Smitty Blackstone and Ken like this.
    May 2013
    Groton, NY
    2,663
    Quote Originally Posted by Peterb View Post
    I've worked on a couple of push mowers that had the "don't change it, just add" engines. I found that to be a little backwards, to say the least. I tore apart a push mower engine this last summer for aluminum scrap. The cam lobes and gear were molded plastic on a steel shaft! Everything is getting to be "throw away"!
    Smitty Blackstone, Ken and Peterb like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
  1. Stripped fork drain bolt????
    By rivershot in forum Technical Help
    Last Post: 11-10-2017, 10:27 PM
  2. Front fork help
    By Adrenaline taxidermy in forum Technical Help
    Last Post: 07-02-2016, 12:08 PM
  3. Front Fork Spacer
    By DSM8 in forum Technical Help
    Last Post: 01-06-2014, 07:54 PM
  4. WTB 2001-newer front fork legs/lower fork legs/front wheel
    By jeadra in forum TW200 Classifieds
    Last Post: 05-06-2013, 02:04 PM
  5. Do I need to drain the oil to change front sprocket?
    Last Post: 01-12-2013, 12:37 PM
