Carb guys, what causes the hanging slow return to idle o the vv carb on a quick blip
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Like Tree93Likes
Thread: Carb guys, what causes the hanging slow return to idle o the vv carb on a quick blip
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Subject says it. Is it the cv slide slow to drop back down that keeps the revs from dropping like I am used to on every other gasoline powered engine in the world. Just one of a few quirky things I do not like about this carb. Also the Racing high idle on full choke on a cold start seems excessive too. Is this normal. I should have my other bike running today and begin to compare.
    EDIT: Sorry for the typos, I'm not worth a darn on my little screen phone and can't edit a subject.
    Last edited by DougDotyTW200; 02-20-2018 at 09:54 AM. Reason: typo apology in title
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Senior Member rivershot's Avatar
    Sep 2014
    Middle GA.
    262
    Sounds like a vacuum leak, check the boot between the carb and head.
    Ken and Smitty Blackstone like this.
    2001 TW200
    1999 DR350SE
    2002 Sportster 1200
    Suzuki Ozark 250 (Broke)
    Rokon RT140 (in a basket)
    Belarus AS250 tractor
    Hailey, ID
    3,404
    Definitely not normal. Also check that the throttle quadrant is returning all the way closed and that the return throttle cable isn't too loose or that the main cable isn't too tight. Main cable should have about 1/16 " of slack when throttle closed and return cable the same when throttle open. You can see the cables bow slightly in their respective positions.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Dec 2015
    San Diego
    1,865
    Yes I’ve had interference with the grip on the throttle too. My bikes have pretty high idle right away on any choke with a 34 pilot jet. With that pilot jet here in SD we don’t need to choke at all. I have little to no lag but I have tuned my bikes for the DG exhausts. Some guys have enlarged the hole in the slide but I haven’t found that necessary. Getting the right needle height using washers for the mid range really made my bikes snappy.
    Jan 2018
    Southern In.
    457
    Quote Originally Posted by Tweaker View Post
    I put a 34 pilot in my 03 as I went through that carb and it will come to life this afternoon so I will have something to compare to. I did loosen the return side cable and it maybe seemed a little better even though i think it was making it all the way back to the stop before, but maybe not quite as snappy and or decisive, maybe a bit a drag with it before. I amde a short video if I can post it, not sure how on this site.
    Ken likes this.
    Jan 2015
    Fair Oaks, Calif
    503
    Before you do anything, adjust your valves! A leaky/tight exhaust valve creates this very symptom!
    Jim
    Tweaker, admiral, Ken and 1 others like this.
    Frosty Hollow
    13,166
    Quote Originally Posted by jtstdub View Post
    Jim
    Would a leaky header to muffler exhaust leak cause this as well? I noticed my XT200 (same engine as the TW) seems to sometimes have the same symptom as what's being questioned here by hanging. On my ride a couple weeks ago I forgot to pay attention as my focus was on the trail.
    Jan 2015
    Fair Oaks, Calif
    503
    Wouldn't think so but Old air cooled VW's sure do not deal with exhaust leaks at the head to header... Causes flat spots.... along with the exhaust popping of deceleration.
    jt
    admiral, Ken and Smitty Blackstone like this.
    Jan 2018
    Southern In.
    457
    Does the video seem normal to you guys, It just seems to be slow in getting back down to idle on a throttle chop. Not just the chop but it seems to be pretty obvious when changing gears and you are wanting the rpm to fall off a little.
    admiral and Ken like this.
    Frosty Hollow
    13,166
    Quote Originally Posted by DougDotyTW200 View Post
    Seems a little longer. I'll listen to the 3 TW's in my shop tonight and see what they sound like after they warm up.
    My XT200 has hung up a lot longer than the TW in your video until recently when I reduced my idle speed in the hopes something sticking was the problem. This did help but not illuminated the hang. So I'm not sure if it's a linkage issue or vacuum issue or valve issue or exhaust issue. I suspect or would hope with a newer TW you wouldn't have one of these issues. I'm curious now about the valves being off and I don't remember a hanging idle before making any valve adjustments before.
  1. Replies: 13
    Last Post: 08-02-2015, 06:57 AM
  2. WTB Carb. throttle return spring
    By N-Forker in forum TW200 Classifieds
    Last Post: 06-17-2014, 10:08 PM
  3. Replies: 8
    Last Post: 01-08-2014, 06:10 AM
  4. 2005 carb issues, slow to idle down
    By MrDNA in forum Technical Help
    Last Post: 10-02-2011, 06:28 PM
  5. Here is one for the carb guys!
    By ewommack in forum Performance and Customization
    Last Post: 05-10-2011, 11:12 PM
news
what is the cause of the idle slow to return
