Oil in Airfilter
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Like Tree33Likes
Thread: Oil in Airfilter
    Junior Member Impala's Avatar
    Feb 2018
    7
    Oil in Airfilter
    Guys I need some advice please. I bought a TW200 from a friend not sure of year. The gasket at the dino leaked so I got a new one and fixed it up this morning. Cleaned the filters and drained the old oil. I then filled with the 1liter of oil and went for a drive. Coming home I checked and saw the oil level has droped below the sight glass. Opened the air filter and the oil just poured out. About the 1liter I put in Came out. What can be the cause of this?
    littletommy, Badgerflorida and Ken like this.
    Biking through Africa with Cornelis
    17,595
    Welcome to the forum!!
    Usually this means blow by. You may need to do a leak down test to see if the rings are ok. When it is running, if you open the oil fill cap, does it smoke out of the crankcase? Hard to imagine a whole liter of oil coming out on one ride. Pull off the crankcase hose going into the crankcase also and see if there is smoke. What year and how many miles? Look for the VIN number and year on the frame near the top and front of the bike. (under steering lock on left side)
    Quote Originally Posted by Impala View Post
    Ken and Peterb like this.
    1st John 1:9
    John 3:16
    John 3:17
    Feb 2018
    7
    Thanks Tommy, I'll have a look on that. And send the VIN Number monday. The clock is on 54000km. And not running, the cable is missing
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,403
    ......... The gasket at the dino leaked ........?
    Oil in the airbox/ air filter is caused by an overfilled crankcase....can't imagine a whole liter of oil coming out.
    Would like to know the cause myself, when you find out.
    jb
    17,595
    I would suggest draining out all the oil, cleaning the oil filter and refilling it before trying again. Put in only one liter again.
    ***Note that the bike is filled sufficiently when the oil is between the lines on the glass and it is to be checked when the bike is held up level, not on the kickstand, or you will be overfilling it.
    Elvesus, jtstdub, Ken and 1 others like this.
    1st John 1:9
    John 3:16
    John 3:17
    Jan 2017
    Southern Nevada
    1,077
    Ample good advice already.
    You may appreciate this thread: https://tw200forum.com/forum/technica...-breather.html
    Any blue smoke out exhaust (sign of worn rings).
    Any oil on spark plug nose (sign of worn rings)
    littletommy, jtstdub and Ken like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Jan 2015
    Fair Oaks, Calif
    503
    Quote Originally Posted by SportsterDoc View Post
    Then we go to that thread and lt leaves us all hanging......No response from the OP... Just sucks!
    Jt
    Ken likes this.
    Jun 2017
    Milwaukee, WI
    1,299
    He still posts on here. Maybe he’ll give an update.
    I agree it left me hanging. Cheers
    littletommy likes this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    Quote Originally Posted by jbfla View Post
    jb
    A TW holds barely over a quart. If you put a whole litre of oil there's your problem. Too much oil pressure from too much oil will blow it out of the crank case somewhere. Usually through the vent pipe into where your air filter is and if it is a small amount will normally collect in the little clear rubber oil catch under the air filter. If it is a lot it may fill up your airbox with oil and make it smoke.
    littletommy and jbfla like this.
    17,595
    A liter is actually the correct amount to put in a TW. A TW calls for 1000 cc's which is 33.814 ounces, one liter just happens to be 33.814 ounces.
    Quote Originally Posted by Ken View Post
    jbfla and turbodieseli4i6 like this.
    1st John 1:9
    John 3:16
    John 3:17
  1. Replies: 20
    Last Post: 04-28-2017, 09:37 AM
  2. Auto oil vs Motorcycle oil?
    By CS1983 in forum Technical Help
    Last Post: 01-13-2017, 04:38 PM
  3. WTB - Oil Cooler looking for an Oil Cooler Kit
    By Skin Walker in forum TW200 Classifieds
    Last Post: 01-01-2016, 06:15 PM
  4. Exhaust & Airfilter
    By wentzel in forum Performance and Customization
    Last Post: 12-16-2012, 10:02 AM
  5. oil cooler and engine oil capacity
    By AFISHALBIZ in forum Technical Help
    Last Post: 07-22-2012, 10:08 PM
news
