aftermarket turn signals
Results 1 to 10 of 12
Like Tree12Likes
Thread: aftermarket turn signals
    Junior Member rumblems's Avatar
    Feb 2014
    16
    hoping i could get some help i put on some mini turn signals on my 2004 tw after braking a front one when i wired up the fronts i didnt hook up the blue because theres no running light on these but for some reason all the new aftermarket blinkers work except the front left its hooked up just like the right i know it works is this an issue with not hoooking up the running lights any help appreciated
    Ken likes this.
    Jun 2015
    Nova Scotia
    1,425
    Maybe it's blown...try switching the left bulb to the right side wiring to see if it still works. I did the same thing to confirm I blew a bulb. Mine have no running lights either. And they work fine except for the blown one I replaced.
    Ken and littletommy like this.
    19,019
    Perhaps check the left light's bullet connectors for a good tight fit into the TW's wiring harness.
    There are also several nominal bullet connector sizes encountered on these aftermarket lights. A set of LEDs I bought came with 0.110" bullet connectors I believe which I had to replace with I either 0.156" or 0.157" to get a satisfactory fit...or was it the 0.180s, I forget.
    Ohhh, the senility of it all.
    I trust the micrometer more than my memory these days.
    Jan 2017
    Southern Nevada
    1,077
    Not connecting the running lights is not an issue...just cap off the wires.
    If bulb is good and socket contact is good, check for voltage to bulb contact and then check that socket shell has a good ground.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Feb 2014
    16
    thanks guys i appreciate all the people who take the time to help others
    littletommy likes this.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    it's because you are installing leds. the front signals get there ground through the dash bulb and they only work in one direction. lots of info in previous posts on led signals
    i'd explain further, but i usually get over run, so i'm sure someone else will be along to explain
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Feb 2014
    16
    theyre not led's and 3 work 1 dont but i thought that at first too
    19,019
    I like SportsterDoc's #4 post, remove lens and bulb and test confirm that a pulsating 12v hot signal and a good steady ground are present at the socket.
    While you have the multimeter out one could also check resistance across bulb's fillimaent even if it has already passed a visual inspection.
    Trail Woman likes this.
    Feb 2014
    16
    yea i think its time to break out a multimeter
    Fred and Trail Woman like this.
    Feb 2014
    16
    ha what a dummy when installing new turn signals i accidently pulled out the connector in wiring harness mystery solved thanks everyone
  1. Stock Turn Signals
    By EWB in forum TW200 Classifieds
    Last Post: 06-20-2017, 12:35 AM
  2. Turn signals
    By yz250f4ever in forum Performance and Customization
    Last Post: 03-16-2015, 04:15 PM
  3. LED turn signals anyone?
    By swmotdub200 in forum Technical Help
    Last Post: 07-07-2014, 10:08 AM
  4. I need.... Rear Turn Signals.
    By Tom Bettiker in forum TW200 Classifieds
    Last Post: 02-28-2014, 12:17 AM
  5. turn signals
    By tw200_87 in forum Technical Help
    Last Post: 08-09-2011, 06:57 AM
