TW200 won't fire.
Results 1 to 10 of 13
Like Tree24Likes
Thread: TW200 won't fire.
    Junior Member Kidatheart1963's Avatar
    Mar 2018
    4
    TW200 won't fire.
    I replace the Carburetor, fuel filter, Air filter, cleaned the fuel tank, replaced the fuel lines. have good fuel flow from the vacuum operated fuel pump. It fires and ran for a minute. Now it has no spark. I cleaned the plug. Not even a weak spark. I held it and grounded myself and usually it will be so strong it will hurt . Nothing now, I looked at the fuse. Still nothing. Any thoughts???? Please help
    Mar 2015
    Ynys Môn
    4,633
    Have you recently changed the front sprocket ?
    Welcome to the madness ....
    - Hidden Content
    Mar 2018
    4
    No, the drive train is all good.....
    Mar 2015
    Ynys Môn
    4,633
    For the record, let’s try not confuse things – the fuel feed is gravity feed on the TW
    Best advice at this point is to trace the wires from the generator on the left end on the crank, up to the CDI, and follow through to the coil and plug connections
    Do you still have power to the rest of the electrics – headlight/tail light/brake light/ neutral light etc ?
    Are you aware of the safety cut-outs on the bike ?
    Side stand/ clutch / neutral etc ?
    - Hidden Content
    Mar 2015
    Ynys Môn
    4,633
    With a green light showing, the bike should fire up as long as the kill switch is in the correct position
    With the bike in gear, the side stand must be up, and the clutch lever engaged (pulled in) before it will fire ….
    littletommy, Ken and Fred like this.
    - Hidden Content
    Junior Member rumblems's Avatar
    Feb 2014
    16
    i had bad kickstand switch took awhile to figure out
    Skiing the slopes in Switzerland
    17,587
    Welcome to the forum!!
    Ken likes this.
    1st John 1:9
    John 3:16
    John 3:17
    19,023
    Perhaps Kidatheart is more clever in a subtle way than we give him credit for. After all it is vacuum that does pull the fuel from the float bowl through the various jets and orifices and thus one could infer a vacuum operated fuel pump for this and every other carburetor in the world. However my first reaction was also "What? Is he talking about a TW200?".
    I would suggest OP reads some of the electrical diagnostic threads and then seek specific clarification if unsure about any item in the vast wealth of information on this forum regarding a no spark situation in a TW200. Remember a well answered response depends on a well formulated unambiguous question so we can focus in on specific help for a specific problem since the subject is so very broad.
    I urge everyone to always test their assumptions. For example just cleaning a plug does not guarantee anything, you are left with an assumption that it is a functioning plug that has not really been demonstrated. Could that plug generate a spark in another device like a lawn mower? Could a different plug like the lawnmower's generate a spark in the TW? Could a spark be generated by bypassing the spark plug entirely? Which fuse was looked at? The spare unused fuse is located right next to the one in service. etc, etc, etc.
    We can help, we just need good input.
    Mel, littletommy and Ken like this.
    Mar 2018
    4
    Thanks for the comments. Ok I don't think we are speaking about what I am working on.. I am taking about a Trail Wagon TW200 4x2 farm wagon. Not a bike, No kick stand. Yes it does use a vacume operated fuel pump. NO Spark is the problem. Its in the wiring I am sure I just was hoping someone had had the same issues.
    Cornelis likes this.
    Senior Member Bruce's's Avatar
    May 2014
    258
    Google shows you have a side by side ,while this site is about a Yamaha dirt bike .I am sure after every bodies initial laughter at the mix up ,there will be several of us to lend a hand .Can you take a picture or two of the engine for us ? It will help to figure out what you are working with .
    Ken likes this.
  1. 2008 tw200 won't start
    Last Post: 10-04-2016, 04:27 AM
  2. Turns over but won't fire off.
    By Truckerbob in forum Technical Help
    Last Post: 08-28-2016, 07:12 PM
  3. Left petcock open for a couple weeks, bike won't fire up
    By Armitage in forum Technical Help
    Last Post: 03-12-2016, 08:03 PM
  4. Replies: 25
    Last Post: 09-27-2015, 11:10 PM
  5. 87 TW200 won't idle
    By heimy in forum Technical Help
    Last Post: 10-23-2010, 06:43 PM
trail wagon tw200
trail wagon tw200 parts
trail wagon tw200 wont start
tw200 trail wagon wont start not getting gas
