5th Gear Question
Results 1 to 10 of 10
Like Tree16Likes
  • 1 Post By Joe Weaver
  • 4 Post By Purple
  • 1 Post By old w/??
  • 3 Post By littletommy
  • 2 Post By raffles
  • 1 Post By Peterb
  • 1 Post By RockyTFS
  • 1 Post By JoelS
  • 1 Post By phelonius
  • 1 Post By vanillagorilla1
Thread: 5th Gear Question
    Junior Member Joe Weaver's Avatar
    Feb 2018
    Charlotte NC
    7
    Talking 5th Gear Question
    Hi guys, I'm new to the TW world (and motorcycles in general), but I bought a 2018 TW200 about a month or two ago and decided to put a 45 sprocket on the back. I mainly ride on country roads so I thought that this would work better for me. While it is awesome between 1st and 4th ( I can get up to 55mph pretty easily in 4th), as soon as I switch over to 5th I really can't get anymore acceleration no matter how much throttle I give it. Do I need to be at higher rpms when I switch into 5th? The bike feels like it's too low to get any power.
    I don't mind not having any more acceleration because I don't have a desire to go much faster than 55mph. However I was wondering if this is bad for the bike in any way?
    Thanks for your help!
    littletommy likes this.
    Mar 2015
    Ynys Môn
    4,630
    Rev the tits off it before changing into 5th - just to the point where you are convinced it has become a competition between the engine exploding, or your teeth falling out
    It does sound as though your 45 is holding the bike back a bit - Yamaha had it about right at 49/50
    The 45 is a trade off - try the original configuration .......
    - Hidden Content
    Apr 2014
    992
    Too little horsepower. But it makes 1st through 4th more user friendly on the street - and 5th becomes like an overdrive; reducing vibration etc. making for a much smoother, more pleasurable ride.
    Vacationing in the Bahama's
    17,573
    A 15 on the front works well or a 47 on the rear.
    1st John 1:9
    John 3:16
    John 3:17
    Member raffles's Avatar
    Jun 2012
    united kingdom (England)
    79
    Quote Originally Posted by purple View Post
    rev the tits off it before changing into 5th - just to the point where you are convinced it has become a competition between the engine exploding, or your teeth falling out
    it does sound as though your 45 is holding the bike back a bit - yamaha had it about right at 49/50
    the 45 is a trade off - try the original configuration .......
    😂😂😂😂😂😂,”rev the tits off it “ , i love your words of wisdom there, more of it please
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    I run a 45 and find it perfect but I do ride faster than 55 mph and I don't mind dropping a gear once in a while.
    Hailey, ID
    3,404
    Quote Originally Posted by Joe Weaver View Post
    ...I don't mind not having any more acceleration because I don't have a desire to go much faster than 55mph. However I was wondering if this is bad for the bike in any way?
    The only reason it may be bad for the bike is that you probably haven't broken it in yet. I'd put the OEM 50 back on until 1,500 miles, and then try it again. As others have said, a 45 is a bit low for all but really flat terrain.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Junior Member JoelS's Avatar
    Feb 2018
    Yokohama, kanagawa, Japan
    26
    I ground off one of my gears a few months ago, I read someplace that 4th gear is a direct drive gear... or maybe the mechanic told me... and 5th is overdrive.
    Here is one of the forums I read about it, plus gear-ratios for the TW:
    https://www.motorbike-forums.com/thr...200-2006.3966/
    One of the gears from my TW last fall:
    (the mechanic said the problem in my case wasn't the transmission but the bolt bushing that holds the swing-arm on, he recommended changing it every 30,000km)
    Attachment 162674
    2001 TW200 30km/18k miles
    rear fender eliminator kit
    round headlight
    custom front fender
    Super Trapp exhaust
    aftermarket chain
    USB charger
    custom paint
    rebuilt front shocks and gear box Hidden Content
    Front Disc and a Kickstart Hidden Content
    Nov 2010
    Frostbite Falls Ill
    2,719
    45 tooth is too high a final drive for a stock engine. I tried a47 and used it for a while but finally decided I liked the stock 14 X 50 stock ratios.
    I now run a 14 X 54 tooth on my 200cc Van Van but then it is also hauling a sidecar. Stock on the Van Van is 14 X46.
    Phelonius
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    805
    I found with the stock 5 speed that I liked the stock gearing the best. That fifth gear Sri always was tough to deal with. When in gravel forest service roads I would hunt between 4th and fifth all day! I suppose the other thing is I learned quickly that you can rev it till the tits fly right off. Eventually I ditched the stock dash and went with a trail tech so that I could know what the engine was doing other than screaming. After having the six speed for a few years I really don’t know why it didn’t come that way. It’s makes a big difference. Your bike is new so enjoy it but if you get the itch the 6 speed 225 sure makes the bike a different animal.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
  1. 5th wheel bike hauler.
    By BigSlick in forum General Discussion
    Last Post: 04-02-2017, 08:23 PM
  2. 5th gear whining noise
    By yamahannes in forum Technical Help
    Last Post: 09-04-2015, 06:49 AM
  3. Clutch Slipping in 5th
    By QCSmith in forum Technical Help
    Last Post: 12-11-2014, 06:35 PM
  4. carb question - flat spot at mid-rpms high gear
    By gamorg02 in forum Technical Help
    Last Post: 07-11-2014, 06:00 PM
  5. 5th gear goes crunch
    By GoNOW in forum Technical Help
    Last Post: 01-14-2012, 09:26 PM
Tags for this Thread
