End cap DG R series
Results 1 to 10 of 11
Like Tree26Likes
Thread: End cap DG R series
    Junior Member SaraRae88's Avatar
    Mar 2018
    5
    End cap DG R series
    Anyone have a hard time taking the end cap off their R series? I’m trying to install a quiet core insert and cannot get the dang thing off! Thanks!
    PlacerLode, Ken and littletommy like this.
    Dec 2015
    San Diego
    1,865
    Hi welcome. Were you able to get all the screws out? If so then use a flat screw driver carefully in the slot around the end casting and the muffler body. You can tap it in several places with a hammer or mallet around the end piece and it should slide off.
    littletommy, PlacerLode and Ken like this.
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by Tweaker View Post
    ...You can tap it in several places with a hammer or mallet around the end piece and it should slide off.
    Good advice
    My mallet is a frequently used tool.
    Just used it last week on my truck to check caliper "float"
    Still made in the U.S.A.
    https://www.homedepot.com/p/Estwing-...-18N/100351737
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member mountain yawp's Avatar
    Jul 2016
    Right side of Oregon
    552
    Welcome to the forum.
    Ken, PlacerLode and littletommy like this.
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    Hi SaraRae88, welcome to the group! Nice to see more women out riding.
    Ken, littletommy and PlacerLode like this.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    Quote Originally Posted by SportsterDoc View Post
    Good advice
    and i just used my screw driver today to screw in a screw
    and welcome to the forum Sara
    Ken, littletommy and Tweaker like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    793
    The cap is really in there tight = I used a small spray of silicon around the seam (after taking out bolts) and then used a screw driver to start splitting open moving an inch at a time around the edge - use silicone spray to help with reinstallation also.
    Oh, and welcome!
    Dec 2015
    San Diego
    1,865
    I forgot they use silicone sealant on that end cap and recommend putting some back on it when installing it. I have some small leaks that don’t bother me after I installed the quiet cores. The sealant will make it harder to get off the first time if it hasn’t been removed yet.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,958
    littletommy likes this.
    Dec 2015
    San Diego
    1,865
    Sararae88 any luck getting your quiet core put in?
  1. exhaust "leak" in end cap screw hole
    By Eric in forum Technical Help
    Last Post: 12-14-2016, 08:33 PM
  2. Replies: 25
    Last Post: 07-08-2016, 01:53 AM
  3. Reinstalling exhaust pipe end cap.
    By Zachary in forum Technical Help
    Last Post: 09-24-2014, 06:16 PM
  4. WTB: Stock Exhaust Insert or End Cap part
    By ilbiker in forum TW200 Classifieds
    Last Post: 05-28-2014, 10:03 AM
  5. End cap for my muffler
    By MCC1776 in forum Technical Help
    Last Post: 04-17-2014, 07:48 AM
