SR241 Mounting Question
Results 1 to 6 of 6
Like Tree13Likes
  • 3 Post By Xaman
  • 2 Post By Trail Woman
  • 3 Post By CJ7Pilot
  • 2 Post By Swingarm
  • 2 Post By RockyTFS
  • 1 Post By Xaman
Thread: SR241 Mounting Question
    Senior Member Xaman's Avatar
    Mar 2012
    168
    Just mounted a new 241 front. Iím no expert but Iíve never had a tire spoon on so easily. And Iíve never had one seat without some sort of snap or pop. Aired it up to 50psi just making sure it seated, and It looks fully right. Then I pulled the valve stem to add Ride-On sealant/Balancer, and it lost its bead on both sides, just kind of collapsed. Aired it back up again, and it looks fully seated as before, just no pop. Went ahead and installed it back on the bike, and will do a test run tomorrow, but nervous itíll slip on the wheel if itís that loose. Any thoughts? Thanks!
    Jun 2015
    Nova Scotia
    1,426
    Sound like my experience except no sealant/balancer...no issues for me. but I'm light on my front break. I'm at roughly 15 psi right now. Off road only.
    Mar 2017
    Yuba City, CA
    405
    My 241 "popped" on, but it was definitely easier to seat than the rear tire! It did not come off the bead when I let the air out to add Ride-On.
    Miaugi, littletommy and admiral like this.
    Senior Member Swingarm's Avatar
    Jan 2017
    Houston Tx
    135
    Both of mine went on easily. I have run 6 psi in my wifes bike but told her to dodge the bigger rocks. Shes also not aggressive on the brake. I have run mine at 8 but did feel some rocks so dont go that low.
    Miaugi and littletommy like this.
    Hailey, ID
    3,404
    I had exactly the same experience with both the front 241 and the rear OEM two days ago when adding RideOn. No pop, and a little hiss when adding air. Put both up to 20 psi and went for a 10 mile ride at 55.
    Zero problems. I have a suspicion that the pop has to do with how much capacity and pressure your air tank has. Mine doesn't have much and only goes to 100psi.
    Yes, the 241 does not have a real stiff carcass....nice if you have to repair a flat tube.
    I ride in sharp rocks a lot and would never go below 12 psi.
    littletommy and Trail Woman like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2012
    168
    Great to hear, thanks all. I shouldnít complain about easy mounting, and I guess Iíll make up for that when I work up the courage to try an ATV rear
    Trail Woman likes this.
  1. SHINKO SR241 Tire Pressures
    By maddawgj in forum General Discussion
    Last Post: 12-18-2017, 04:52 PM
  2. Installing new tires: Shinko SR241 and TW34
    By sjh953 in forum Technical Help
    Last Post: 09-16-2016, 07:52 PM
  3. Replies: 0
    Last Post: 06-15-2015, 04:10 PM
  4. Super moto front fender mounting question
    By Logsplitter in forum Performance and Customization
    Last Post: 04-08-2014, 09:46 AM
  5. For those that have a Shinko SR241
    Last Post: 05-19-2013, 03:05 PM
