Starter heat soaked?
Results 1 to 10 of 17
Like Tree21Likes
Thread: Starter heat soaked?
    Senior Member spewingjason's Avatar
    Oct 2017
    113
    Ive been riding my 95 a bunch the last few days, pretty much running perfect now after some carb tweaks and suck. I've noticed that after an extended slow speed ride(looking for deer anlters in the grass) that it cranks like that battery is dead, not enough umps to spin it over. Will fire right up first kick though. Cranks like crazy and fires right up cold though. It kinda has to be the starter to only be effected when the engine is the hottest i'm thinking. I may swap starters with my 87 and see if the problem follows the starter. Does not present itself as a connection issue but will obviously check them. Anyone have starter issues on one of these?
    Jan 2017
    Southern Nevada
    1,077
    More like engine heat, rather than starter.
    Are you feeling any power loss?
    What is ambient temp?
    Oil level good?
    What is battery voltage while cranking?
    Spark plug looking lean?
    Carb jetting?
    littletommy and Miaugi like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Vacationing in the Bahama's
    17,573
    Could just be the battery isn't staying peaked up due to idling/putting around. With the lights, brakes etc being on, its possible you are drawing more than you are charging. Also, some TW's don't like having the start button held down restarting when hot. Just a quick push on the button worked for me most of the time. How old is the battery. Have you considered load testing it?
    1st John 1:9
    John 3:16
    John 3:17
    Oct 2017
    113
    Ambient temp was 65ish this afternoon. Unlikely its jetting, 118 main jet(old style carb), #42 pilot, I think mixture screw is around 2 or 2-1/8 turns out from seated. Oil level is ok, its only happened a couple times in the field, so no volt meters with me. Starts IMMEDIATELY with kick starter when it does this. Battery came to me with the bike, so its questionable, but zings it over pretty good cold, so I'm leaning towards it being ok, but I wouldn't be terribly surprised if a battery fixed it.
    littletommy likes this.
    Oct 2017
    113
    I get a pretty good discount at Batteries + Bulbs, I might just snag a batt tomorrow and see what happens.
    littletommy and Peterb like this.
    17,573
    Have them load test it.
    Quote Originally Posted by spewingjason View Post
    1st John 1:9
    John 3:16
    John 3:17
    Oct 2017
    113
    Thanks LittleTommy, if I have time to pull it out in the morning I’ll do that.
    Junior Member JoelS's Avatar
    Feb 2018
    Yokohama, kanagawa, Japan
    26
    Mine was doing that and I almost bought a new starter. I pulled it and when I looked at the drive pinion on the end of the starter that goes in the engine I notice it wasn't moving freely, it was sticking - gummed up. I cleaned it (should move easy) and its been working great. My bike is an tw200 2001 model.
    2001 TW200 30km/18k miles
    rear fender eliminator kit
    round headlight
    custom front fender
    Super Trapp exhaust
    aftermarket chain
    USB charger
    custom paint
    rebuilt front shocks and gear box Hidden Content
    Front Disc and a Kickstart Hidden Content
    Jan 2017
    Southern Nevada
    1,077
    ...Battery came to me with the bike, so its questionable, but zings it over pretty good cold, so I'm leaning towards it being ok, but I wouldn't be terribly surprised if a battery fixed it.
    What are voltages starting it cold?
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Hailey, ID
    3,404
    ...... I've noticed that after an extended slow speed ride(looking for deer antlers in the grass) that it cranks like that battery is dead, not enough umps to spin it over. ......
    I had this same problem because I ride so slowly much of the time. The stator doesn't put out enough juice to keep the lights on and the battery charged up below about 3,000 RPM. I pulled the connectors on the always on front signals and the low beam on the headlight. Problem solved. I just turn on the high beam when on the road.
    It could be other stuff, but here is where to start. Pull these connectors, tape off the male sides, charge up the battery good and see if the problem disappears.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Muffler Heat Shield
    By TopPredator in forum Technical Help
    Last Post: 09-22-2016, 10:21 PM
  2. Anybody need a great Heat Gun?
    By Darth in forum General Discussion
    Last Post: 01-16-2016, 10:49 PM
  3. Beat the heat....
    By mudbug in forum Off-Topic
    Last Post: 07-12-2015, 10:39 AM
  4. Anybody tried Heat-Out gear?
    By DonBenito in forum General Discussion
    Last Post: 06-17-2014, 05:25 AM
  5. Extreme Heat Wave in the NE
    By scotti158 in forum General Discussion
    Last Post: 03-08-2014, 05:59 PM
