Kitaco rear drum brake pads
Results 1 to 6 of 6
Like Tree18Likes
  • 2 Post By JoelS
  • 4 Post By Xracer
  • 3 Post By Ken
  • 5 Post By phelonius
  • 3 Post By Peterb
  • 1 Post By JoelS
Thread: Kitaco rear drum brake pads
    Junior Member JoelS's Avatar
    Feb 2018
    Yokohama, kanagawa, Japan
    26
    Has anyone ever tried Kitaco rear drum brake pads?
    Any tips on the instillation?
    2001 TW200 30km/18k miles
    rear fender eliminator kit
    round headlight
    custom front fender
    Super Trapp exhaust
    aftermarket chain
    USB charger
    custom paint
    rebuilt front shocks and gear box Hidden Content
    Front Disc and a Kickstart Hidden Content
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,818
    I've tried several after market brands. None of them work as well as stock Yamaha.
    Ken, Peterb, littletommy and 1 others like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    I just checked to see what I used, Yamaha oem. I also have a question. Are the front and back brake drum pads the same? I know on a car these are brake shoes. I changed the back pads once and the front ones never. The only issue I had with the drum brakes was that they would stick when it was damp out and would grab until the moisture was gone. I put a small dab of antiseize on all the pivot points and I never had another issue.
    Nov 2010
    Frostbite Falls Ill
    2,719
    The brakes on my 93 TW would stick and I would have to put my toe under the pedal and lift to release them.
    I put new shoes on and twas okay for another year then same thing. The problem was the drum was worn to a bigger diameter
    And I had to get a new hub to fix the problem. High milage TW owners take note.
    Xracer, Ken, JoelS and 2 others like this.
    Phelonius
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,491
    Xracer "I've tried several after market brands. None of them work as well as stock Yamaha."
    I agree and that goes for most parts except steering head bearings, chain and that front tire of course.
    JoelS, Smitty Blackstone and Ken like this.
    Feb 2018
    26
    Quote Originally Posted by Ken View Post
    Thanks, the back brakes were sticking a little, the bike just turned 30,000km last month. I will add antiseize on all the pivot points and switch back to OEM on my next set.
    Ken likes this.
    round headlight
    custom front fender
    Super Trapp exhaust
    aftermarket chain
    USB charger
    custom paint
  1. Rear brake drum won't fit the mounting plate! Help
    By VinnieFingers in forum Technical Help
    Last Post: 07-03-2017, 09:51 PM
  2. Rear brake drum interchange?
    By deker in forum Technical Help
    Last Post: 05-12-2016, 06:37 AM
  3. Rear Drum Brake Issue
    By watkins in forum Technical Help
    Last Post: 04-17-2016, 11:45 AM
  4. WTB - TW200 Rear Brake Drum
    By Darkestarc in forum TW200 Classifieds
    Last Post: 12-01-2015, 10:36 PM
  5. Rear drum brake 2001
    Last Post: 11-12-2013, 12:16 AM
