cutting the spring
Results 1 to 10 of 13
Like Tree11Likes
Thread: cutting the spring
    Apr 2013
    385
    cutting the spring
    hi there,
    a friend wants to make a bobber/low seat style tw, parts are difficult to find here, especially when he's not sure what to look for and add the language barrier
    if we cut the spring off an inch or so would this work? I've seen it don't on cars, not that was the way to do it either.
    cheers
    Mar 2015
    Ynys Môn
    4,637
    Not so sure - the rear shock doesn't have a lot of travel to begin with, and you risk blowing the seals
    Have you looked into hard tailing it ? - (which is pretty much what you'd end up with anyway) .....
    Smitty Blackstone likes this.
    - Hidden Content
    Jun 2016
    New Rochelle, New York
    1,803
    Try Web Bike in Japan. They have all that weird bob any bike stuff, even for TW's:
    Motorcycle Parts & Accessories from Japan - Webike Japan
    Nov 2010
    Frostbite Falls Ill
    2,719
    TWs have little enough travel as it is. Don't do it.
    Phelonius
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    Drill the swing arm like I did you won't loose any suspension travel and it drops the rear ~3"
    Apr 2013
    385
    peters, do you have a picture of the bike for reference? thanks
    Apr 2011
    1,485
    I'm 5'10" for reference and my wife is 5'1"
    Senior Member Chip's Avatar
    May 2017
    WI
    267
    Lowering link??
    2017 XR650l
    2014 NC700X
    2005 ST-1300
    Wanted TW450
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    PeterB has the best solution, I have drilled cut and welded the rear swingarm and found it to be surprisingly soft steel and easy to work with...
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Apr 2013
    385
    sorry Peterb, your name got autocorrected!!, i cannot open the links you sent
  1. Cutting out when hot
    By watkins in forum Technical Help
    Last Post: 07-31-2016, 06:31 PM
  2. Cutting out under throttle
    By EWB in forum Technical Help
    Last Post: 01-03-2016, 11:26 PM
  3. Replies: 2
    Last Post: 06-06-2014, 09:18 PM
  4. cutting out a minute or 2 after movin?
    By dubstep in forum Technical Help
    Last Post: 12-12-2012, 09:45 PM
  5. Cutting out
    Last Post: 03-14-2012, 05:58 PM
news
