Idle speed adjust....very stiff.
Results 1 to 8 of 8
Like Tree23Likes
  • 1 Post By Trail Woman
  • 5 Post By Fred
  • 5 Post By RockyTFS
  • 3 Post By jb882
  • 2 Post By Trail Woman
  • 5 Post By jb882
  • 2 Post By Badgerflorida
Thread: Idle speed adjust....very stiff.
    Jun 2015
    Nova Scotia
    1,425
    Does anyone have a fix or suggestion for this stupid idle adjustment? The fact that it loops around to the other side seems like a pointless aggravation and I'm considering cutting it off and modding it to the one side..Any suggestions? Reasons not to alter it?
    19,019
    Yamaha's flex cable is exceedingly stiff for the application, could have been made out of smaller cable. When I adjust mine I open throttle a bit to lessen force on adjuster as I turn it. A few drops of oil along length of cable seems to also help.
    Purple, Badgerflorida, Ken and 2 others like this.
    Hailey, ID
    3,404
    Both of mine turned easily with two fingers. I think you need to lube it like Fred said. Could it also be corroded?
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member jb882's Avatar
    Aug 2013
    1,376
    What Fred said about opening the throttle a little... I also find a little dab of anti seize paste on the threads where the cable threads into the carb helps a lot. I would remove the cable, clean the threads of any corrosion and smear some anti seize on the threads of the cable before you screw it back in.
    The only reason i can see not to modify it is the location of the exhaust. You could burn your hand or arm on it while trying to adjust it if you removed the cable and put a regular adjuster in its place.
    Badgerflorida, Ken and Trail Woman like this.
    Jun 2015
    Nova Scotia
    1,425
    It's only 3 years old stored in a dry building so I doubt it's very corroded. I tried some lube and it only turns a hair back and forth...might need too some time to do it's thing.
    Badgerflorida and Ken like this.
    Aug 2013
    1,376
    You don't need moisture for galvanic corrosion to happen, just two dissimilar metals which is what that screw and carb are. Moisture just makes it worse.....
    I bought a brand new carb a few years back that already had corrosion on it right out of the box, the screw was stiff and needed a lot of persuasion to come out, it happens.
    Jun 2017
    Milwaukee, WI
    1,292
    +1 Fred. Slight twist of the throttle will make it turn much easier.
    Smitty Blackstone and Ken like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Hailey, ID
    3,404
    Quote Originally Posted by Trail Woman View Post
    ... I tried some lube and it only turns a hair back and forth...might need too some time to do it's thing.
    What kind of lube? Liquid Wrench? PB Blaster? Something is not right here, that knob should be easy to turn. You may have to remove it and see if it is real stiff when not connected.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. WANTED: throttle screw to adjust idle
    By docjekyll2002 in forum TW200 Classifieds
    Last Post: 01-26-2018, 11:33 AM
  2. Warp Speed Idle
    By lafester in forum Technical Help
    Last Post: 08-07-2014, 11:58 AM
  3. Replies: 2
    Last Post: 06-06-2014, 09:18 PM
  4. Replies: 8
    Last Post: 01-08-2014, 06:10 AM
  5. idle speed
    By mike m in forum Technical Help
    Last Post: 01-29-2012, 06:58 PM
