Engine Year Model
Results 1 to 4 of 4
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    I have an extra TW200 motor but do not know the year model. How do you use the serial number on the engine to determine the year?
    Senior Member rm_hm's Avatar
    1,619
    This was all I could find.... Might or might not work.... If all else fails call or email your local dealer.
    http://www.ehow.com/...ne-numbers.html
    Maybe we should have a sticky thread where we all enter in our bike year and engine numbers? That should be enough to narrow down a year...
    Desert, SoCal
    7,369
    The short answer is that you can't. There aren't enough identifiers.
    You can narrow it down by the type of camchain adjuster, stator and carburetor.
    There are 3 basic "series" of motors. All are mechanically identical except for carbs, camchain tensioner and stator type.
    87-only has a manual camchain tensioner, slide carburetor and seperate lighting coil in the left sidecover. '88-'00 have a manual camchain tensioner, slide carb and single-phase charging system. '01-up have an automatic tensioner, CV carb and three-phase chatging system.
    '01-up also typically have 8mm hex head bolts on the side covers and crankcase halves, but that isn't neccessarily set in stone. Early motors have JIS Phillips head screws.
    Oct 2011
    Central Arkansas
    69
    Thanks. I knew it wasn't a 1987 but was curious what year model it is. It has no carburetor on it but from you information, it has to be a 1988 to 2000.
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. How do I tell which year model I have?
    By brah1 in forum Technical Help
    Last Post: 01-11-2013, 06:55 PM
  3. 2012 Model
    By Senior Dirt Dog in forum General Discussion
    Last Post: 08-25-2012, 02:48 PM
  4. model question
    By maupin81 in forum General Discussion
    Last Post: 06-01-2011, 12:12 PM
  5. Identify your T-dub Model Year
    By TrailWhale in forum General Discussion
    Last Post: 08-09-2010, 05:59 PM
early tw200 carb
